2022 2500 Chevy gasser......I know this topic has been discussed before, and I know GM said all is good. BUT, I never had that terrible sound until I had the oil changed at the dealer at 2500 miles.  Ever since then, every time I do a cold start I hear this, of what I think, is the timing chain just rattling like heck for a second.  I've checked the oil, it's fine, the dealer of course used a GM oil filter.  There has to be a way to fix this.  I hate it and want to get rid of it, the sound that is....I love the gas engine....best engine ever.  I just want it to not make a horrific noise on start up like it did before I had the oil changed for the first time.  Any ideas how to solve that?
My 23 makes the same noise.  Sounds like it’s coming from under the cab?  No idea what it is.  Hopefully its not like the gawd awful noise my 3.5 EcoBoost used to make, but that was cam phasers.
My 6.6 gas makes the same noise on cold starts. I explain it the same way, sounds like a timing chain rattle. I was at the dealer last week for an oil change and I brought it up but of course they didn't know what I was talking about. I couldn't leave it there for several hours for them to do a cold start to reproduce it.
I had the 3.5 Ecoboost in our 2019 Explorer Sport and never had a problem or noise out of it.  Now, I did my own oil changes and used Mobil 1 with the factory oil filter.
I'm trying to figure this out...that 6.6L gasser is to die for.  I absolutely love it....But why on earth does it make that noise?  I've read that the oil filter check valve to keep it primed isn't working...I call BS on that theory.  Something changed drastically when my first oil change was done at 2500 miles...  Now what is different?  The only thing different is oil and filter.  Nothing else.  Unless GM put in some kind of additive to their oil......hmmmm...  edit again...I bet GM was using a thicker based oil.  Like a 0 or a 5W-40.....That would make sense for initial break in for an engine that is robust as this one is.
Edited by Jettech1
I don't know. I am friends with the service manager at the dealer. I sat down with him in his office and he looked it up in the system to see if he could find any kind of bulletins describing the noise but he could not. I guess I'm just not going to worry about it for now. If it for some reason gets worse, than I will make plans to leave it with them so they can cold start it.
I'll figure this out and let you all know.  That's what I do.....lol...be well....
It's not the oil filter check valve, it's the oil pump itself. It bleeds back and gets air in the veins of the pump. The sound is the pump shoving that air through itself while is sucks up oil to send through the engine.
It does no harm to anything and these oil pumps have been doing it since 2014 when the LT engines came out. It's worse if you park on the incline and anything below like 40 degrees outside.
If you bought the truck in the summer, you'd never hear it.
It's almost always hot here. I hear it everyday.
I did buy it at the end of August which is hot as hell here in Atlanta.  But it immediately started making the noise when I had the oil changed early October.  It never made a peep until then....
So if that's the case, why did it not do it before I had the first oil change?  That's what has me scratching my head here...it's like, what the hell happened with just an oil change....
Make sure that a PF63 filter is on there and that they used 5-30 oil and not 0-20. I work on the line at a GMC-Buick dealer and can tell you that the oil changes are usually done by the newest inexperienced ****** heads that they can find. Mistakes happen every day. I would not let half of them put air in a bicycle tire. Just something to check.
Pray tell how this can be accomplished, perhaps with the Bill Nye science set? 😉
Is the oil level good?  On your paperwork, is there a p/n of the oil used?  Did they install a PF-63 filter?
Can you give us a video of a cold start?
Without hearing it I'm leaning towards normal.  Its the oil pump that is making the noise.
14-06-04-004H: Various Engine Noises During Cold Start and Warm Engine Operation - (May 12, 2022)
Oil Pump Cold Start Rrrrp or Rasp
The oil pump design has changed from a gerotor gear type pump to a two-stage vane type pump for fuel economy reasons. At temperatures at or below 0°C (32°F), or when the engine has been sitting for a few hours, it is possible to have air enter the pump through normal oil drain back. Upon startup, the owner may hear a short “Rrrrp” or “Rasp” coming from the front of the engine. It is most often heard during a remote start.
There is nothing wrong with the oil pump or oil system. No repairs should be attempted for this condition.
Edited by newdude
  • Thanks 4
    • https://www.msn.com/en-us/autos/news/fuel-economy-stickers-don-t-tell-the-whole-story-aaa-data-reveals-why/ar-AA26ocHk?ocid=winp2fptaskbarhover&cvid=6a4122ea3dae47e5b8dfbed5d4fd3d55&cvpid=648f6b4fc2fa4eddb4c12893aeb957ed&ei=59
    • What’s missing in all this is patience and investment in the future. Buy a 170K starter home. Ten years later sell it invest in a more expensive home. Eventually you’ll have a 600K home and pay starter home payments. Buy a starter car. Maintain it well. Save the payments after it’s payed for then buy an expensive car if you desire. Buy a tumbler make your own coffee, pack your lunch. Cook your own dinner. Most importantly take care of your car.
    • People mislead themselves. Statistics are highly useful indicators.   Here's the tie-in to this thread. If an oil sample tests shows a wear indicator of 7 using cheaper ACDelco oil, and a wear indicator of 2 (lower = less wear) using a particular brand of Mobil oil, and wear has a linear relationship with engine lifespan, anyone could assume that Mobil is reducing wear by more than 50% (let's just say a 200% reduction for you red state people trying hard to do math) which leads to increasing engine life by 2x. Perhaps, in a vacuum, by itself, when dreamed by AI.   Yeah?! That's what the statistic is saying, isn't it?   No, it isn't. It didn't come out and say engine life is doubled. That's a very bad assumption, and a case of severe myopia by assuming something potentially untrue about the only data point in focus.   Average cost of a new car is 50k. You bet it is.   The median cost of a new car is more like 35k. Expensive cars are skewing the perception that "average" now means a $50k price of entry for a very average automobile. And that's not true. People who don't understand statistics twist the living heck out of them to mean all sorts of things they don't actually mean.   "Average" new car payment is $1000/month. Yep, it is. And in that number are all the $35k new car buyers who bring significant equity, and the $25k new car buyers who finance the car for a month just to get a rebate, and then pay it off. Know what isn't in that number? All the payments made by people who don't finance a car.   Picking one's own data point (don't have a car payment, never paid $50k for a new vehicle, my house cost $170k, I afforded a middle class lifestyle on $4.50/hr) is just a data point. Just like earning $25/hr in an area where the median home price is almost $1 Million is a data point. In fact, it's a lot of data points given that 80% of the US population lives in/around major cities. They're not idiots; the vast majority of them do it to make a living because that's where the big money is.   The highs have become higher, lows have become lower, and how your personal mileage varies is not truth for an entire country. At the same time you can't NOT acknowledge the data. While it doesn't paint YOUR personal picture, it certainly tints the reality that you also live in, as does your single data point.
    • Glad you had success with it. I did as well, but about 5-6 months later it returned. Tried again, same result. This was after the dealer made several attempts and never even got it to slow down.
    • 3.15 Kroger’s in Montgomery Tx
