Hey all,
I had an Extang Solid Fold 2.0 on my first truck that I have had in storage. I replaced it with an Extang Xceed Low profile folding - it leaked too much after many adjustments, so I put the Solid Fold on and now it seems to be leaking from the outer hinges.
What do you recommend for a hard folding tonneau that is as waterproof as possible? Any remedies to make an existing more water resistant?
Thanks
20 hours ago, Moose0814 said:
Hey all,
Thanks
I am on my third roll-x..well now it's called BAK Revolver X4S Tonneau Cover...  IMO they provide a good balance of security, water tight and visibility out back window if you don't have the camera mirror.  I get a little water intrusion at back by the tailgate but I haven't been worried about it.
I have an Undercover Ultraflex. Nice cover and all, but i have a lot of water intrusion. I haven’t cared all that much, there are a number of things that could be done to reduce that but it’s a shame to have to come up with solutions on your own for a $1000+ cover. I know none of them are really water tight but there are some WTF points on this cover that I feel they could have designed a little better.
If I was purchasing again I think I’d try a backflip MX4. They look a little nicer. The advantage the Ultraflex has over the MX4 is that the final hinge point is closer to the cab, so the cover doesn’t stick into the bed as far. I can actually load my full size dirt bike without removing the cover (corner to corner), I don’t think I would be able to do that with the mx4. Also that the Ultraflex doesn’t rest against the cab when fully open like the MX4.
I have the Gator hard tonneau on my 21. I think it is actually made by Undercover. If you buy from Realtruck.com, they will usually discount the price for you through a chat session. It has been pretty good with keeping out water so far. the foam extrusion they provide for install is pretty thick stuff, but I am not sure how long it will last. I may look to replace it this spring if it looks like it is starting to dry.
I have the factory hard folding cover and it's been great. I get very minor leakage around the back tailgate in car washes and heavy rain, but its very minor. When we go out of town we load everything in the bed and don't worry about it. Even when it's rained, it's been very minor drops at the gate.
I also have a Gator. Really like it. I have owned several over the years. They all leak. Some just worse than others. The only leaks I have with the Gator is in the very corners. Has not cause me any issues as it just drips right down and out of the drain holes in the corners of bed. Everything still stays dry inside bed. I just don't put anything in the corners of the bed that I might not want a few drops of water on. Center stays completely dry between wheel wells.
My low profile rough country tri fold stayed bone drove on our 1600mile drive this week. Drove through a rain and snow storm. If you're military or prior they have a discount that can be applied over the phone. Supposedly it's a lifetime warranty.
On 12/20/2022 at 11:25 AM, Moose0814 said:
Hey all,
Thanks
Have you tried replacing the seals? its kind of a pain but will get it back to the way it was
I started out with a Gator soft roll up as it was cheap.  Upgraded to the Gator EFX hard fold and it was a really good cover.  I decided to change out for one that would give me full bed access so I stepped up to the BAK MX4.  I was very unimpressed with the MX4, it was built very cheaply compared to my buddy who had an MX4 that was a few years old.  Overall the Gator EFX I replaced was a better cover that I should have kept.  I got rid of the MX4 it and went with a Lomax Stance in carbon fiber.  I'm loving the Lomax.  Lightweight, water tight except for at the tailgate which will eventually be remedied once I install a tailgate seal.
I am going to order them soon and replace! the foam bumps have to be replaced as well. thanks!!
I had the Bak Flip on my 2019, and had the dealer install the Rev on my 22 Refresh Denali before I picked it up.  They are the same design, and both have been relatively leak free.  The Rev has a better seal across the front of the bed than the Bak Flip did.
Edited by SPASierra
    MASONV88888888
    MASONV88888888
  • Who's Online   4 Members, 0 Anonymous, 1,009 Guests (See full list)
    • https://www.msn.com/en-us/autos/news/fuel-economy-stickers-don-t-tell-the-whole-story-aaa-data-reveals-why/ar-AA26ocHk?ocid=winp2fptaskbarhover&cvid=6a4122ea3dae47e5b8dfbed5d4fd3d55&cvpid=648f6b4fc2fa4eddb4c12893aeb957ed&ei=59
    • What’s missing in all this is patience and investment in the future. Buy a 170K starter home. Ten years later sell it invest in a more expensive home. Eventually you’ll have a 600K home and pay starter home payments. Buy a starter car. Maintain it well. Save the payments after it’s payed for then buy an expensive car if you desire. Buy a tumbler make your own coffee, pack your lunch. Cook your own dinner. Most importantly take care of your car.
    • People mislead themselves. Statistics are highly useful indicators.   Here's the tie-in to this thread. If an oil sample tests shows a wear indicator of 7 using cheaper ACDelco oil, and a wear indicator of 2 (lower = less wear) using a particular brand of Mobil oil, and wear has a linear relationship with engine lifespan, anyone could assume that Mobil is reducing wear by more than 50% (let's just say a 200% reduction for you red state people trying hard to do math) which leads to increasing engine life by 2x. Perhaps, in a vacuum, by itself, when dreamed by AI.   Yeah?! That's what the statistic is saying, isn't it?   No, it isn't. It didn't come out and say engine life is doubled. That's a very bad assumption, and a case of severe myopia by assuming something potentially untrue about the only data point in focus.   Average cost of a new car is 50k. You bet it is.   The median cost of a new car is more like 35k. Expensive cars are skewing the perception that "average" now means a $50k price of entry for a very average automobile. And that's not true. People who don't understand statistics twist the living heck out of them to mean all sorts of things they don't actually mean.   "Average" new car payment is $1000/month. Yep, it is. And in that number are all the $35k new car buyers who bring significant equity, and the $25k new car buyers who finance the car for a month just to get a rebate, and then pay it off. Know what isn't in that number? All the payments made by people who don't finance a car.   Picking one's own data point (don't have a car payment, never paid $50k for a new vehicle, my house cost $170k, I afforded a middle class lifestyle on $4.50/hr) is just a data point. Just like earning $25/hr in an area where the median home price is almost $1 Million is a data point. In fact, it's a lot of data points given that 80% of the US population lives in/around major cities. They're not idiots; the vast majority of them do it to make a living because that's where the big money is.   The highs have become higher, lows have become lower, and how your personal mileage varies is not truth for an entire country. At the same time you can't NOT acknowledge the data. While it doesn't paint YOUR personal picture, it certainly tints the reality that you also live in, as does your single data point.
    • Glad you had success with it. I did as well, but about 5-6 months later it returned. Tried again, same result. This was after the dealer made several attempts and never even got it to slow down.
    • 3.15 Kroger’s in Montgomery Tx
