Many of us have, this body style has been the same since 2019. They handle 5,000-6,000lbs just fine.
29 minutes ago, pete harlock said:
sorry...should have specified 2022...
A 2022 isn’t really different than a 19-21. Under the new grill and the new dash it’s the same truck as far as towing is concerned. The towing app in the infotainment system is different but I don’t think that’s what you’re asking about.
Exactly what feedback are you looking for?
I went on a 2300 mile round trip in my 6.2L 2022 refresh. 4500 lb car on a tandem axle aluminum trailer. Pulled like a boss. 85MPH no issues up hill and down hill.
I tow 6000 with my 19, 5.3L all the time.  No issues whatsoever.
I use a heavy duty weight distributing hitch also.
Truck rated for 19,200 and 6000 travel trailer is nothing to it!
Edited by DiverRick
I don't think there's much difference either. Except most 2019s have the sucky eight speed transmission. How is your truck set up? Max tow package, standard tow? Engine size. Six thousand pounds is not much. But then, you have to consider what is loaded on that trailer and total weight. Don't forget, the tow rating in the manual means total weight.
I have a 2019 Sierra SLT, 5.3, eight speed. I tow a 20'enclosed trailer with two 1000# motorcycles, plus luggage, two people, and other stuff. I've pulled it through mountains and had no problems. That is except fuel mileage, 11 mpg with that load.
i have the 2022 RST, 3.0 diesel, max tow package, 3.73 rear end and all this is cleared to haul 13000 lbs...
unfortunately, when hooked up to my new travel trailer, a Service Trailer Brake message is displayed
in the DIC...GM says the cause is unknown and they are working on it...so much for going south for the
winter....😠
winter....😠
Common problem, there is another thread about it, looks like a new switch has just been released (in the las few weeks) that fixes it.
winter....😠
Same issue here with a refreshed TB 5.3, very frustrating, but glad to hear of a possible fix.
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
