The Denali comes with a standard bed with spray on bedliner. The Carbon Pro bed option is a $115 up charge. Seems like a no brainer. Right?
Is this a must have? Are there downsides? I would be adding a folding hard tonneau and some sort of mat {probably Bedrug) to keep things from sliding around.
Are there ordering restrictions?
Thanks.
Thanks.
I just got my 2023 Denali but I ordered it with all options as the Ultimate except with Jet Black interior. So I have the CarbonPro bed.
I just got in today my OEM Rev Flip hard cover and OEM bed rubber liner.
Part number
Short Bed Tri-Fold Hard Tonneau Cover in Matte Black by REV® (for Models with CarbonPro™ Bed) - Associated Accessories
Part No. 19433570
Bed Mat in Black with GMC Logo for Short Bed (for models with CarbonPro Bed)
Part No. 84635351
I am going to save the $300 and do the install myself.
here is a video on the install it appears.
Edited by Denali_1500
57 minutes ago, Aubie_01 said:
Can you get the Carbon Pro without a bunch of other packages?
I was a separate line item on my window sticker since I ordered my Denali completely as I wanted. Only took 7 weeks to get the truck from the time I ordered.
DENALI CARBONPRO EDITION 1,125.00 • CARBONPRO COMPOSITE BED
I have not seen a topper/cap for a CP bed.  Other than that, it's great.  I throw split wood in mine w/o fear of denting the bed.  Plus, it's a bit lighter.
Part number
Part No. 19433570
Part No. 84635351
Thanks for the part #'s and the install video. I guess the REV tonneau has the same rail attachments. Just have to wait for our taxes to get done and make sure we don't have any surprises. We always seem to pay.... Grrrr.
Luckily, I really like the Ultimate interior. Sort of reminds me of a King Ranch I had.
Edited by Jus Cruisin
  • 6 months later...
house of hazards
Thanks.
The only downside to the Carbon Pro may be its slightly expensive price tag.
4 hours ago, Jennings Lorna said:
house of hazards
$115 was the cheapest option on my truck. And, after 6 months of ownership, it's a must have now.
So just bought a slightly used 2021 1500 AT4 w/ the carbon pro package. I always have a canopy on my truck. It was never disclosed to me and I never thought to ask about mounting a canopy to my bed. Because you can mount a canopy to every bed on the market. However the carbon beds are slanted and there is no flat surface to put the C clamps to secure the canopy. I have called a LEER/ snugtop installer and they called their reps and they have no "approved" fix for this. I have also called an ARE dealer who called their rep and they have no "approved" fix. Then I called SmartCap they sent me pictures of a customer that had cut holes for the clamps to fit through but stated this was the customers doing and not an approved method. I am now contacting dealerships to figure out what GMCs fix is. I can not imagine that they built the only bed in the world that you can not attach a canopy to.
Does anyone have any insight into this issue or any approved fix?
CarbonPro is only available as a short box.
The standard box (6.6") is only available in steel.
Carbon Fibre composite bed is optional and only available on AT4, Denali and Denali Ultimate.
I don't understand why you believe GM would have a "Fix" for this issue as it's not an issue for them, it is an option in which the original buyer wanted, you bought it used and expected that it would work for your needs but it doesn't, GM isn't going to "Fix" that. I looked at a truck that had that bed and knew it wouldn't work for my needs so I found another one without that option, works great!
I looked it up, I didn’t know what it was. It’s a 10K option. I don’t know how one could be bought by accident.
I am glad you found what you were looking for. When I told the dealer my plans for the truck they said nothing about the inability to put a canopy on the bed. After calling them and talking with them it seems they had never heard that was an issue. Why would I think that this bed would be different than any other bed in the world. I would think that there should be a way for a canopy to be attached to the bed or they tell you that? I know that its an after market addition but its not a foreign one lots of people put canopies on.
It's your canopy manufacturer problem not GM's. Bellyache at your canopy manufacturer to create a mounting solution. GM can't or shouldn't have to fix aftermarket issues. BakFlip has created unique mounting brackets for their tonneaus for the CarbonPro beds.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
