I've had these MRR T228 for 2 months now and have been at the shop 4 times to diagnose a shaky wheel/tire combo at highway speeds. I had Toyo proxes st tires and went thru a combination of 7 different wheels and 7 Toyo's before the shop ordered some Nitto's the same size. The Nitto's were put on and the truck STILL shook so we put the stock 18's on and the truck drives great, NO SHAKE. Any help? MRR is to the point they almost don't wanna help and I'm having to look into new wheels. Anybody went thru the same thing?
You need a shop with a road force balancer. With that not all the shops that have them use them correctly. That balancer will tell which wheel or tire is out of round.
They've mentioned they do, yes,  and they got them to the point where the wheel and tire spun correctly with the Nitto's on on the balancer, then they put them on the truck and it still shook. So the way he explained it was its correct on the center cap and off balance on the lug holes. That where I'm at out.
Ok well if that Truly is the case all you'd need is a hub centric ring. I would start by getting a micrometer and measuring the wheel hub bore and truck hub.
1 hour ago, Snowcamo said:
Could also be wheel hubs gone bad.
Doesn't seem likely that stock tires and wheels would correct it. Unless they are able to mask it enough to not be noticeable.
Try, keeping three factory tires and wheels on and put 1 of the MRR set ups on one at a time to try and see if there is one or more of the MRR's causing the problem.
Inspect the hub mating surfaces for debris or manufacturing defect preventing the MRR from mounting properly.
Make sure the lug nuts aren't bottoming out on the studs before tightening to the wheel.
They would correct to the point it's not noticeable. Only due to less weight. I can put first hand experience with it as my truck came with 17s factory.
Pull a wheel off and look at the brake rotors.  Do you have any of these tinnerman nuts/clips on there?  The little bronze colored ones in the picture below.  If you see them, take them off.  They can cause an imbalance with aftermarket wheels and GM accessory wheels.
READ HERE - MC-10162155-9999.pdf (nhtsa.gov)
Torque and Clamping Force - Tire Review Magazine
Edited by newdude
Also.  Center bore would be worth checking.  OE wheels are 78.1mm and MRR has those T228s at 87.1mm so I don't know if its actually larger?  Or did they just transpose the digits?
I would figure at some higher speed you’d notice eventually but I could be wrong.
I’d does have the rings on it yes.
Update, the new running theory is it isn't the wheels, it's the driveshaft. Dropped the truck off to get the driveshaft pulled out and balanced and will come back. I was on a long interstate drive on my 18's and started to feel it very lightly compared to when the 22's were on, so the larger tires were taking most the shake out.
Sorry for the delay, I've not had the truck in almost a month. 7 wheels were replaced, 6 tires were replaced before changing brands from Toyo to Nitto. All the wheels/tires and now showing they are good and don't require any weights at all. The owner of the shop even took them to another shop to use another machine just to check that off as well. The driveshaft has been balanced and the shop "checked the rear end" and it showed true, yet issue is still ongoing. The wheel hub surfaces are flat with no washer on lugs. The truck still shakes at the same speed, about 65-80 or so, as well as at a lower speed you can feel the truck jumping or hopping at maybe 15-30 mph or so. The only other thing I can think of is maybe torque converter? As I've read that a lot but I thought that was more of a 6.2 issue. Any other advice? This does not make any sense to me....
About to roll this truck off a bridge, it's bad enough you can't have open drinks in the cup holder on the interstate/parkway.
    • In their own words:    https://blog.amsoil.com/how-engine-sludge-forms-and-how-to-prevent-it-2/   [Quote] Synthetic Oil Helps Prevent Sludge Fortunately, sludge and varnish deposits are something that can be controlled. Using thermally stable synthetic base oils reduces the rate of degradation (oxidation).   Antioxidant additives further help reduce the rate of degradation. One of the most widely used is zinc dithiophosphate. Not only is it an excellent oxidation inhibitor, but it is also an outstanding anti-wear additive.   High-Quality Additives Fight Sludge Fortunately, it is possible to address many of the issues that occur after the initial oxidation stage. Additives, such as detergents and dispersants, help promote the suspension of contaminants within the oil and keep them from agglomerating.   Detergents, which are also alkaline in nature, assist in neutralizing acids generated in the sludge-building process. Antioxidant, dispersant and detergent additives are consumed during use.   To achieve maximum life expectancy, use a motor oil with high concentrations of antioxidant, dispersant and detergent additives.  [End Quote]   So quality base oil and then the last sentence above. TBN and ZDP levels matter. The one thing not covered was sufficient viscosity. Sad.     And yet we now have since API SN lower amount of them all with the only real change being a slight up tick in base oil selection. Along with lower concentrations of everything that makes oil work and lower and lower viscosity there is still an insistence on longer OCI's.    How low does the peanut butter and jelly level have to get before we say it's just white bread folded?    The new smoke and mirror treatment is the 'additives are INVISIBLE' to UOA testing with a health dose of TRUST ME.    I'm not picking on AMSOIL. This is coming from all of them. Every last one of them that abandon the low wear model in favor of the high mpg/EPA compliance model.
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
