Preparing to change oil now that my truck is reaching 500 miles.  I do plan on towing (TT, boat).
For those of you that use M1, which flavor do you prefer and why?
I read that the Truck/SUV flavor is for towing.  the ESP is rated for 20K miles.
I plan on severe duty OCI (approx. half of regular OCI  which is 7500mi).
All three of these flavors meet the GM recs of...Dexos 1-Gen 3
Thanks!
Edited by SoCal Angler
26 minutes ago, SoCal Angler said:
Preparing to change oil now that I my truck is reaching 500 miles.  I do plan on towing.
I read that for Truck/SUV flavor is for towing.
All three of these meet the GM recs of...Dexos 1-Gen 3
Thanks!
"Truck & SUV" = Marketing.
It's got a slightly stronger additive package.  10% more additives vs. regular Mobil 1.
Thanks!
All of these are good to go. I just used truck and suv for the first oil change in my 24’ HD. I plan on sticking with truck and suv unless I can’t find it, then I’d be good with “vanilla” Mobil 1.
I'm new at this oil selection/analysis, as I have not purchased a new truck in many years, but...
After doing some reading on the subject, I believe it's probably more important to determine best OCI schedule based on oil analysis, then go with the oil flavor that delivers the best results.
I would like to know more about oil analysis....
  • At what mileage should analysis begin (considering a new truck)?
  • At what mileage intervals?
  • What key components are important to monitor in an analysis?
  • Is there a "break in" mileage that is used as a base line when beginning an analysis to determine best OCI?
  • How many analyses are needed to determine a base line?
  • Since there are variables in miles accumulated between analyses (towing, not towing, city, hwy, etc), how is the OCI determined based on these varying analyses?
Now, since I'll be changing oil at 500 miles, and say I'm using the M1 AFS....
1.  Would an oil analysis be worthy at 500miles?
2.  What would be the analysis schedule/interval to ultimately determine best OCI?
Perhaps I'm way overthinking this....
Since no one chimed in.....
Wear is high initially. BEST ring seal is not instant. Meaning blow by is higher and yet normal. This eats up acid add packs more rapidly than it will in the near future. Also means wear metals will be higher now than any time before late stage wear out OR failure. Fuel dilution will also be higher until rings seal up a bit. 500 miles is a great first change.
In my stuff I do another at 1,500 and 2,500 and then 5,000. Or 1K, 1K and 2.5K. At 5K run two samples. One on the new oil and the other on the used. The first is the benchmark for the second.
In these early samples I'm looking for a few things. Initial new TBN vs used TBN and TAN new vs used. And I'm looking at 'stay in grade" on the 100C/212F viscosity. I will note other items such as fuel dilution and wear metals.
If you cheap out and run only TBN then OCI is set between 50% depletion from new. If you really cheap out and run ONLY the UOA, then a 4 TBN is the basement. IF you run both with TAN and TBN then don't let the TBN fall below the TBN.
Pay attention to the 100C viscosity. If it falls a below the grades minimum value, look at the fuel dilution. If over 2.5% the cause could be a fuel or spark issue. If the fuels are 2.5% or lower find a new oil. This one sheared out the cheap VII package.
I see this motor calls for a 5W30. IMHO, a 10 cSt 100C viscosity is a must.
FOLLOW THE BOOK recommendations for towing during the break-in and check those differentials early for proper fill.
Edited by Grumpy Bear
You are likely to get different recommendations from every response. I am not an expert, nor do I claim to be. I can only speak from my experience and research along with I believe has worked for me so far.
I do the first oil change at 1000 miles (I don’t see anything wrong with 500 though). Then I change it again at 5000 miles. From there forward, I change it every 5000 miles.
I generally won’t consider UOAs until I am at 15,000 miles. At this point it seems that everything is beginning to  settle down after break in. I typically will do UOA from 2-3 oil changes to get a solid baseline. A lot will depend on your conditions and use. I’ve always been ok with the results that I get from these 5,000 mile OCIs. I have no interest in extend drain intervals. After I establish a baseline I will send off for UOA every 20,000 miles for condition checks.
Once again, YMMV. This is what I am comfortable and confident with. You are probably right, all of us involved in conversation like this is way overthinking it. Few take the time for any type of analysis, yet we don’t see cars sitting everywhere with blown engines. I have always taken care of my vehicles, but have only gotten more ****** about it with age. I never did any analysis on my Silverado that I traded with almost 400k miles on the clock, or a couple of F250s that were pushing 300k when they were sold. All vehicles just received routine maintenance with quality products.
Thanks!
I would run Mobil 1 Extended Performance 5w30 or 10w30.  Don't be concerned with TBN.  It's not considered a valid test by GM or Cummins.   Get the oil tested for oxidation instead.
Edited by TunaFresh
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
