Is anyone experiencing dealers unable to do warrantied repairs for lack of parts available?
Purchased my 2023 GMC Sierra SLT in January 2023.
I've had a damaged (full of condensation) headlight since October and all I can get from the dealer SA is "it's on backorder".  Pretty ridiculous if you ask me.  If they can make new ones (which they obviously are) they can spare one for a truck under warranty.
Pretty common issue. Especially when the factory is working 3 shifts 7 days. New vehicles take piroty over warranty parts. I would call gm customer service direct at corporate for help
Welcome to the last 3 years.  Oh and the strike did NOT help either.
And no, they don't just pull them off the line just for some customer's truck to get fixed.  Parts for vehicles being assembled are "just in time" production so they are ready to go at the plant as those trucks are getting built.
GM CCA is in charge of the parts flow for after the purchase/after the car is assembled parts flow.  CCA = Customer Care and Aftersales.
As long as the dealer has a SPAC case on it and their parts department is following the case and keeping in touch with GM and their GM DMA (district manager) then that's really all they can do/you can do.
Edited by newdude
Not gonna make you any more satisfied but parts shortages and back orders have been around for many many years. Way before any strikes.
It took months for me to get a regulator rectifier for a Yamaha outboard that was under warranty
Same deal. Not just automotive.
Took a month to get a starter for our Hyundai, replaced under warranty.
Last year my wife’s Genesis a 2011 at 115K miles the starter went out. Two days later after that being replaced along with plugs, injecting cleaning, belts, hoses and a leaking crankshaft seal we got it back. Amazingly a year later they didn’t have a starter available sooner. Maybe everything is better in Texas. 😎
GMC customer support is now in the mix, for what it’s worth. They contacted the dealer and relayed the same message I was told by the dealer.  Not sure how that is helping but that’s the facts.
 I thought there might could be a way to contact other dealer parts dept.’s to try to find a headlight but I’m just using common sense.
If I could I’d drill some holes to allow the condensation to escape until a new one is installed but I seriously doubt they’ll allow that.  I’m sure the light can be remanned by someone but it’s going to be harder the longer it’s wet in there.  I’m actually surprised it’s still working.
I’ll update when I get it replaced.
With Customer Support involved, you now have some extra eyes on the situation. Maybe check in with whoever is overseeing the case every couple of days to see if there are any updates, and you could also stop by the dealership to ask if they have talked with the district rep about the situation at all.
Keep checking, asking for updates, and repeating the basic message of "I really need your help here." Be sure to email the concerns over the light going out and becoming a safety issue - that will get it digitally added to the case for reference. Don't worry about it actually dying - that's ultimately their problem to deal with. If it DOES finally give out, you could then ask about alternative options for a vehicle to drive since your truck would ultimately not be legal to drive with a light out (and that's why you express the concern ahead of time and get it into the file).
Just got my truck back from dealer after 2 months and during the strike.  Under warranty for a faulty coolant valve (i forget the actual name) couldnt drive the truck. Under reduced power due to the sensor. it sucked, but GM did put me in a rental.
Mine 2020 has been setting at a dealership for 2.5 months waiting on parts, no end in sight. So tell me why I should ever buy another GM product?
Also the dealership called and wanted to buy my truck for $25.000.00!, why would the dealer want to buy a truck that they can't get parts to fix unless they can.
I thought the Duramax 3.0 was supposed to be reliable
1 minute ago, Marvin24 said:
One other question hold did you contact GM to file a complaint?
Just look up the Customer Support number for whichever manufacturer and call...
In my experience, I never approach opening a case as "reporting a complaint." I stick to facts, relay concerns about GM not supporting the dealer's efforts, and avoid being negative about the dealer themselves. You don't necessarily have to start it out as a negative campaign and create even more tension with the dealership...
  • 6 months later...
All I can say is good luck and be happy if you can still drive your vehicle. I bought a brand new '24 Sierra Denali 6.2 in February. Engine light came on April 5th. Total engine failure at 1400 miles. They got a new engine in a week. GM required the radiator be replaced at the same time though and they didn't know how long until they would get one. It's now the middle of June and the dealer says GM SPAC says they have the part but for some reason can't get a delivery date on it. Yeah, they gave me a loaner but I'm sick of paying on a luxury truck that I have driven for less miles than I have on their base Sierra loaner. This is just bad customer service all around.
    ncleg
    ncleg
  • Who's Online   1 Member, 1 Anonymous, 1,371 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
