9 minutes ago, Pryme said:
I suppose I’d get a letter if mine is affected?
When I had 5 vehicles effected with the wiper motor circuit board fiasco in the 90's, it was an orange colored postcard.
I'd rather them send me a switch than have some rando paw apart my truck. Funny they are just replacing the switch instead of issuing a new top tailgate trim WITHOUT holes in it. They probably weather"proofed" the new switch by melting rubber or wax or something over the exposed switch leads. Water will still drain on to it, but now it won't matter so much? Dunno.
Siliconed my holes closed right after getting my truck. Logically couldn’t see a reason to allow water to drain into tailgate. Still holding strong today.
I just put my VIN # in and it said no recalls.  I wonder if their database has been updated or there are trucks that will not be affected by it.  Is anyone else seeing that their truck is part of this recall when checking online?
I too checked my VIN on the Chevy site and it showed “no recall” so I’ll check again in a few weeks. My gate has not malfunctioned yet.
Checked GM website and my VIN did not list any recalls.  I have not received a letter/postcard.  My gate has not malfunctioned, but I do not live in a typically wet area (well, it is raining now and is supposed to for the next 4 days!).  My truck is garaged and is driven as a second vehicle, so not many miles of use.
NHTSA email came today. My gate holes have been siliconed for two years and the gate works fine. Not taking my truck in to get grease stains on the seat for this.
LOL, it's not so much the grease stains that I worry about, it's that they move my seat.....I don't have memory seats and I want to kill them all for doing it...lol..It will take me a couple of days, if not more to get it back to where I like it.  They should never move someone's seat....lol..
Edited by Jettech1
  • Haha 2
Mine never gets moved but I know this truck is one of the only vehicles I haven’t needed the seat all the way back. It’s like two small notches from the back. And for me the angle is easy to find. If it had the pump up seat feature that would be hard to get where I’d want it.
I have the 10 way power seat option on mine but no memory...It drives me nuts when I take it in for an oil change and someone thought it would be a good idea to mess with my settings while just driving it into the bay...I'm 6 1 for goodness sakes......why they have to adjust my seat for their liking is beyond me.  My wife is a little squirt and if I have to move her Explorer I just fold myself up and move it to wherever.  I think I'm going to put a piece of paper on my steering wheel next time that says if you touch my seat adjustments, just go ahead and give your body and soul to Jesus.....lol....
  • Haha 1
I wasn't sure where the holes are for letting water in the tailgate until I read a detailed post here. The holes in the tailgate handle are covered by the lip of the rear door on the ARE cap on my truck. If it's not a water leak issue, I still wonder if the tailgate would open with the rear cap door latched.
If it is a water leak issue, why not just put a piece of duct tape over the holes instead silicone in the holes.
On my last 3 trucks, I had the power seat all of the way back to drive. My 24 AT4 HD is the first truck that I do not have to have the seat all of the way back. It does have memory and have it set up for me and my GF. Also have it set for all of the way back for entry and exit.
You think duck tape would work and look better than silicone? Not even close. For the same reason you don’t see duck tape holding glass aquariums together sir lol.
you can’t even notice the tiny flush dabs of silicone in those little holes
I don’t plan on using silicone or duct tape, it was just a thought. I covered the two holes with a $3k ARE cap! :)
If I notice any water dripping in the holes with the cap door open, I’ll silicone it.
38 minutes ago, BB&Chiveon said:
What holes?
    • Anyone have any info about backorder time? It's classic 4th of July hot here in ohio.
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
