Hello, I got a 2023 Chevy 2500 Custom (6.6 gas). My question is I’m tired of having dealership do my oil when I’m more than capable. I love Amsoil on my old diesels but unsure what you all think? I get a discount from them so cost is fine and also what filter? Amsoil on that also?
I’ve read alot about catch cans on these motors? I had one on my old Cummins but I’m failing to see why on these? Should I add that to my list also? I’m at 11k miles
Amsoil is fine for oil.  5w30 in the 6.6 gas.  OE, XL or Signature series, all great options.
Filter, AC Delco UPF-63R or Wix WL10255 or WL10255XP are great options.
Catch cans.  I never ran one on my 2018 5.3.  The idea on gas engines though is carbon buildup because these are direct injection.  No fuel to wash the back of the valves/intake ports.  I've seen many engines opened without a can that looked good, but also some that didn't.  Those that didn't seemed to either have long oil change intervals with lower end oils, or were driven very pampered and never got a good ring seal.
  • Like 4
Amsoil is ok if you can't find Mobil 1 readily accessible.  Okay that was just to stir the die hard Amsoil guys.....🤣  Any quality oil and filter does the trick, some are just a step above the others, just like gasoline and top tier gasoline, I always go for top tier even if it's a few cents more.
I actually can get Mobile 1 at my local Walmart. That’s why I’m asking and curious if it’s worth the order for Amsoil or not
You can never go wrong using Amsoil products. But, use a reasonable oil change interval and you'll be fine with many of the top oils. It's all in how you feel about the products. I use Amsoil products for certain things.
M1 is not what it used to be, but still will perform well. Last I heard about off the shelf stuff Penzoil Ultra Platinum was the top performer
Edited by txab
I have used both M1 and super tech full synthetic in my truck. I don’t notice a difference and never burned a drop of either. I don’t go over 4k mile oci so I’m not spending amsoil money although I did put amsoil severe gear in the rear diff. I also run amsoil in my motorcycle and atv.
For the OP. I can give a lot of info on putting a catch can on a L8T/6.6 gasser if you want to PM me i have pics.
Is it needed, absolutely not, does it do something yes. Mostly, when its cold, it sucks moisture out of the oil before it would get burnt off anyway. Warmer weather it doesnt catch much, but some moisture.
    There was information i stumbled across wile researching catch cans for the motor that explained whats going on in the valve covers that it isnt needed.
Hear is a couple pics of the ( intake tube ) side that goes between the passangers side valve cover and the air intake box. Its easy to remove the tube. I did, tube was spotless as well as the connecting spots, note the clean Q tip swabs i swabbed the tube and connection points. So seems no oil or vapor is/was getting into the intake.
   I installed the can one day before the first oil change at about 5,400 miles.
NOW, if you want my imput on using a HUBB reusable oil filter, i have that also, and really love it.
Edited by lineman1234
All good information posted.  If you are already getting the discount, I take it you are a Preferred Customer. Then why not keep it simple and use AMSOIL. Less having to have different brands.  The OE line is a great oil and the least expensive in a full synthetic.  If you want one that is a lesser cost then you can use the synthetic blend.
AMSOIL came out with the synthetic blend for the quick lube business's. It has over 50% synthetic stock in it and is a great choice if you change every 3k or earlier.
I use the OE line in a Hyundai Santa Fe, our daily driver. Like the oil and it stopped the adding oil  between oil changes. I was using Castrol Edge on 3K OCI's, adding a small amount before changing it. I think I was adding 6-12 ounces.
My truck sits a lot so I use Castrol, if it goes back into service it will get Amsoil OE.
I have used Amsoil oil in 3 motors,the Hyundai, a Honda ATV and a Kawasaki side by side. They are all quieter.
Edited by diyer2
I was thinking of going to Shell T6 5W40 next oil change. I have 22,000 miles on the Odometer now. I use it in my bike for years. And the lawn equipment. I mainly use AC/Delco oil filters. Have used Purolator, Wix, and Fram when it's the only one I can get. Thought about K&N, like the idea with the nut on the bottom. I change oil every 5000 miles. But been laid up and it's not driven that much right now. It been a year and a half now have only just got 2000 miles now. Towing and short trips. It's black and I'm going to change it.
You're considering the K&N because it has a nut on the bottom? 😒 The purpose of a filter is????? And the nut does what toward that end?
I actually like Shell Rotella T6 5W40 in motors than use no or very little oil on reasonable OCI's. But my idea of reasonable for a Group III base oil is a bit shorter than 5K. Yea, even with such a stout AW package and it's nicely balanced acid pack. If you are waiting for the oil to turn black..... :rolleyes:
Few people buy enough of an oil 'within the same production lot number" to make it worthwhile to run a VOA which might give them enough information to know something to base future UOA's upon to make EDUCATED decisions on things like OCI. So I get a little lost on the idea that anyone can read a UOA or worse a dipstick, and come to some conclusion a hat could be hung on. On what basis are we making decisions? Tea leaves? Thumbs up likes on Facebook? Heck, few VOA/UOA's have enough information or the right information.
My L8T sounds the same, cold and warmed up, with new fresh oil as when just before its dumped with the recommended around 7,500 or when the dash gaugy thingy sais to change. Im very happy with my choice of my 2024 3500 gasser. Darn motor just puuurrrrrs.
Almost time to change oil on it, 3,000ish miles of it are towing a 10,000lbs tall 5ver with added wind drag of front AC unit. Not a noticeable drop of oil used. I would have to go look, but i think its at 25,000 or 26,000ish miles now.
The motor hasnt died yet using a reusable oil filter, and the catch can still catches some kind of crap.
I think its a great motor and transmission. For my needs.
    btm
    btm
  • Who's Online   2 Members, 0 Anonymous, 1,378 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
