I'm moving forward with a new truck purchase in the next few weeks and struggling to decide which engine to go with. I live in CA and don't tow. Typically drive 20,000 per year. My typical commute is 35 miles each way with 90% country roads at 55 mph and freeway at 65 mph, a combo of the two. I do get up the mountains frequently so the extra torque from the 6.2 and 3.0 appease me. I do understand having the turbo will be helpful at elevation compare to a NA engine.
I was initially all set on the 6.2 but with the recent notice from NHTSA, It's got me thinking twice.
Never owned a diesel and don't feel overly confident I can feed it the proper/required diesel living in California.
What would you all go with? Trim level wise going RST or LTZ. Deals seem to be better on the LTZ with the 3.0.
I have a 3.0 and 16,000 miles later I am still amazed at the fuel efficiency over my 5.3 Avalanche I had previously.  I know gas prices are a different world on your side of the country but I ran a spreadsheet for almost 15,000 miles and came up with about 30% more cost efficient across all types of driving versus my Avalanche.  I see a roughly 50% increase in fuel economy so the 30% number takes into account the higher cost of diesel versus regular unleaded.  At typical highway speeds (I don't drive more than 70mph typically), I'm at more than 31mpg.  Around town is about 22mpg.  I know you mentioned not towing, but apples to apples towing, I was right on 50% more mpg with the same load over the same trip.
One thing I did not calculate is DEF usage but to be honest, it's so minimal of an expense that it's not worth factoring in.
I think you'd find the fuel economy for your typical commute would be fantastic in the 3.0... I have the older 3.0 in my refreshed '22 and I've only heard that the newer is better in every way (including more power).
As for trim, I'm very happy with my Z71 RST, just enough bells and whistles without being a sticker shock situation.
Thank you for your post! What kind of diesel do you have in PA?
The 5.3 now and the 5.3 in your older Avalanche is not a good comparison in mpg. My 5.3 on a 650 mile trip got 25-27 mpg and around town it gets about 18- 20 mpg and iam not that easy on the peddle, yes the diesel will get a little better but you have to figure in the up charge for the diesel.
Standard ultra-low sulfur diesel is everywhere here (I think this is the same you'd have in CA).  In the winter, most stations switch to a winterized blend of #1 and #2 but I haven't noticed any difference in fuel economy or how the engine runs.  I typically fill up at one of the truck stops a few miles away as their prices are consistently less than your run-of-the-mill convenience store.
What year Silverado do you have in your 5.3 and trim level? And I would agree, the 5.3 with the 10 speed is a night and day difference compare to the 2004 and 2012 I had.
We have very few #2 diesel stations left in the state from my research. It's all bio or renewable diesel. The owners manual states you can run up to B20 but it's recommended to use a condition or fuel additive with it.
My other 5.3 was a 2019 with the 8 speed and I replaced it with a 2025 5.3 with the 10 speed, the 2025 hasn't been on that trip yet so iam expecting a little more but honestly I don't worry about mpg.
Hooray for the People's Republic of California! 🤣
Just now, PunchT37 said:
My ‘25 LT 2wd 5.3 with 3.42 gears has done this, at least at times.
Wow. Impressive. Thanks for sharing.
My '23 3.0L has done this -- for 28,000 miles.
This is all fuel used.
Hand calc numbers are a little better than the DIC numbers.
Lifetime average is at 29.2 usmpg.
The 3.0 fuel mileage is absolutely unreal. Glad GM still has this as an offering in the half ton market.
My last 3 trucks, '12, 17 and 21 were all 6.2l.  My 2024 I got the 3.0L diesel for the fuel economy.  I have 2 friend who bought earlier versions, 2020 and a 2021, both GMC's and they tell me no complaints. Granted this owners have kept their trucks stock, no suspension lifts or big tires. Like me they have them for basic transportation.
2024 GMC Sierra Denali Window Stikcer.pdf
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
