1 hour ago, Byrds8 said:
According to that 0W40 oil you listed, it's not Dexos R certified. No where on the bottle does it state or mention it. The only one that does that I have found is Mobil 1 Supercar. I found some local on sale for $8.99qt. Still more expensive than the Pennzoil Platinum 0W20 I was using.
Oh crap, I didn't know it was a specially designated oil. Is there an actual difference between "R" and "non-R", or is it marketing hype?
https://www.gmdexos.com/brands/dexosr/index.html
How interesting that even the SuperCar formula doesn't mention "dexos R" anywhere on the bottle, front or back, unless I am blind (which is entirely possible).
Don`t worry about Dexos. Get some real oil in that thing.
  • Thanks 2
They were so worried about Dexos 1 gen 3. Better have it for spec AND warranty. Then, they went against themselves.😉
Couldn`t have been that damn important.
  • Thanks 1
Please note: GM dexos R engine oils meet or exceed the performance of GM dexos 2 and GM dexos 1 Gen 2 and Gen 3 oils and are backward compatible, therefore vehicles equipped with gasoline engines that used GM dexos 2, or GM dexos 1 Gen 2 or Gen 3 may use a GM dexos R licensed engine oil of the appropriate viscosity grade at their next oil change.
Yeah I saw the gmdexos website. But when reading the bottles they don’t even mention dexos or have the emblem.
I thought the Supercar said it. My bad, maybe it doesn’t.  It does have the dexosR emblem on it though.
Edited by Byrds8
Of course all stuff with the 6.2 comes out fully after I bought a 22 GMC Serria with 33k miles on it. It seems to run just fine, but I won't use the oil % thing at all ,going to change every 4k from now on and use a upper cylinder lubricant in the fuel also disable the DMF. It came with no auto stop and glad about that. There is just to much going on with that deactivation of cylinders and I think it causes it's own problems. I bought a V-8 and going to drive one, the mileage is low 20's and I'm good with that. P.S. the 6.2 is a blast to drive
Edited by Bruce Rinehart
spelling
the engines are not completely assembled by robots to my knowledge, some of my friends worked on the lines at delphi in lockport and some at tonawanda about the time robotic hands came into the mix.... but i'm not exactly sure about the engines.  regardless, to reduce repetitive strain on wrenching, people wear robotic hands that probably turn the cap bolts in this instance to a specified rotation or a torque.  the problem is the torque is being reached for the wrong reason, the bore is too small.  tear downs are finding rod bores thousands, many thousands too small and wasting bearings before the 1st oil change or up to 35k miles-ish depending how many thousands the bore is out.  not many people do oil analysis, I am only at 2500 miles so my next oil change is coming in 1500 miles.  did the 1st one at 1000.  looked like normal wear but i'm a september build.  it does have an unnerving rod knock sound but that could be a lot of things.  next oil change will be 0-40 and i'll be interested if the knock goes away.  i also run a range technology on our yukon 6.2. to eliminate dfm and start stop.
knowing how delphi was, i doubt there's qc on the rod bore cause it'd really slow down the process.  if every rod bore had a diameter check on it, somebody would be intentionally letting them by..... at this volume that is highly unlikely and it'd be a specific vin range based on a certain shift.
the oil change just gets the ones failing around the warranty mark to get passed the warranty mark and attempts to appease NHTSA.  this should have little impact on a quality class action suit because, they should be offering a 100,000 mile warranty if they believe it's the actual fix.  that'll be the outcome of the lawsuits which is still cheaper than engine replacement...
oil analysis and out of round crank rotation or piston travel are the ways to check this, but realistically the pan has to be dropped.  they could put a gauge in plug and check to see if the piston travel is less than expected by thousands and directly correlate that to an out of tolerance bearing.
  • Thanks 2
18 hours ago, OnTheReel said:
Two things can be true. No doubt some manufacturing defects occurred. But nobody should believe thicker oil will fix that!
I bet GM views the 0w40 as a good hedge against future UNRELATED warranty claims in currently healthy motors. The 0w20 served its purpose shoving these trucks under the CAFE limbo bar. The only thing it costs them to change spec after that is a 10 cent oil cap. Cheap insurance?
Absolutely! But what it can't be, is absolute and also random if we are going to make the unfounded claim the it is "metallurgy'. Lack of foundation your Honor! :crackup: Absolute and random are incompatible. And I don't think I've heard anyone say the failure rate is 100%. Or even 10%. You couldn't get GM to say if they had a mouthful.
I also haven't hear @newdude offer his observations made during teardowns and/or warranty inspections. If someone has 'real' recon on this....this would be our guy....right? Dirt? Clearance issue? Batch specific metallurgy would have been traced and trapped by now and those specific units recalled. They may not be telling him Diddly but he has eyes and is quite capable of unbiased observations.
What has my feathers ruffled is so called "Science Guys" reading chicken bones sprinkled with bat blood chanting Vo Doo mumbo jumbo looking for sign. It also irks me that they like to "Say a thing to truth". Make false claims about what is and isn't said and building arguments based on unrealities. He's a member of the KKK. I have no proof but If I say it so, its so. All very Trumpian. :idiot:
they are being toredown and found many thousands smaller than spec.  I had a video clip of a couple, i'll try to find the link.
  • Thanks 2
Almost all the "improvement" as these standards progress is rooted in cleanliness testing and lowering NOACK values. And these 'improvements' are fractional. The R spec oil difference is not the HTHS value. In fact is sits right at the very bottom of the J300 spec for its classification. What is different the ZDDP level. 900 ppm minimum both Zn and Phos, W40 oils are not subject to the SP limits 😉 And it's SSI value (Shear Stability Index). A quirky little ambiguous value that says I suffer little "permanent shear" but who knows how much "temporary"...the part used to qualify "Energy Conserving". What some call a 'feature" that I call a flaw.
This non-sensical word salad is why I pay little attention to licensing and a lot to testing.
Well, that will wipe a bearing out. 😬 Yea, oil won't fix that. Guess that is why they said "after inspection'.
Point of clarity. Bearing clearances generally follow the formula a thou per inch of diameter and have since the dawn of the ICE. "Many" thousands and it would be locked upon assembly. Half a thou under minimum is killer. Yea, I know, it's the Internet. 😂
Edited by Grumpy Bear
You sound informed. If this is the case NO lubricant will solve. Just DELAY. INEVITABLE
AMSOIL's Signature Series 0w-40 was originally blended for the MOPAR Hellcat engine and Nissan GT-R, but it also meets/exceeds the dexos specification and would work well in place of Mobil 1 R.  Plus you can get it delivered to your door.  I run a special for all GM-Trucks members, just PM me for the information. I can't post it in public per AMSOIL.
0W-40 (AZF): API SP, SN PLUS, SN…; Chrysler MS-A0921, MS-12633, MS-10725,
MS-10850; Nissan GT-R; GM dexos R
https://www.amsoil.com/p/amsoil-signature-series-0w-40-100-synthetic-motor-oil-azf/?zo=521390
Edited by Black02Silverado
  • Thanks 1
    RyGuy43
    RyGuy43
  • Who's Online   0 Members, 0 Anonymous, 430 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
