I think the thing that I find most interesting is GM has been aware of some sort of potential issues on a swath of Gen 5 small block.
I've linked 3 below.
PIP5308B SES Light P0521 P06DD And Low Oil Pressure - 14-18 L83 and L86
MC-10206733-9999.pdf - diag tip
23-NA-170 1..3 -  This condition may be caused by a crankshaft bearing failure and/or possible damaged thrust bearing.
Mind you, engines like the LT1, LT4, L8T, LV1 and LV3 found in that last one 23-NA-170 use 5w30 or 0w40 oils.  So to me, this all seems to be a quality issue along the way somewhere.  Bearing supplier issue, rod machining issue, crank machining issue, block machining, engine assembly, etc.
Edited by newdude
  • Thanks 2
21 minutes ago, PunchT37 said:
Don`t the 5.3`s and the 6.6`s use these same rods? They seem to be the same on the gm powertrain website specs.
From above even if they did if you are not level in the block for the crank its gonna tear up and eat the bearings fast.
11 minutes ago, newdude said:
No.  And i think you mean 6.2 as the 6.6 has a longer stroke.
All 3 engines have their own p/n connecting rods so that would indicate to me they are not the same.
5.3 uses rod p/n 12649190, 6.2 uses rod p/n 12714549 and 6.6 uses p/n 12675746.
5.3 and 6.2 both do have a 92mm stroke but don't use the same p/n rods.  6.6 is 98mm stroke.
The p/n 12714549 6.2 rod is used in LT1 2014-current, L86 2014-2018, L87 2019-current and the LT2 2020-current.
The 12649190 rod in the 5.3 believe it or not is in a whole bunch of LS engines and then the LT based L83, L82 and L84.  Serviceability dates back to 2004 LS1 and LS6, 2010-2015 LS3 and L99 6.2, 06-09 LS4 5.3, LS2 and then a slew of LS 5.3s from 04-14.  Might explain the lack of 5.3 bottom end failures on the L82 and L84?
6.6 rod is exclusive to the 6.6 L8T.
That`s what iv`e been trying to figure out. The 5.3 to 6.2 failure ratio.
Is the DTC P0016 code going to show up on regular code scanners or it is tied to a specific GM subsystem that only dealer scanners can access?
I would assume it is a "global" code but I have a cheap, basic scanner and see nothing?
Now back to our regularly scheduled viscosity debate ...
  • Haha 1
Were there changes from from 2020 to 2021 on the L87? Why aren't the 2019-2020 model years included in this recall?
  • Thanks 1
Any code reader that can pull ECM codes can read it.  P0016 is a universal OBD II diagnostic code that is one of many that all auto manufacturers use for OBD II protocol.
P0016 is Crankshaft Position - Intake Camshaft Position Not Plausible.
My only guess here is this 21-24 issue came as a result of some sort of change, either in quality or supplier or something like that.
Far enough less to not warrant a recall.  We've replaced 4 6.2s so far, one truck is currently getting its 3rd engine.  We have done no 5.3.s.  Our sister store has done 3 or 4 6.2s as well.  This is in the past 12-18 months?
Are all of them bad?  Possibly not, but its big enough of an issue to warrant this recall.
Edited by newdude
Mine as well, I just can't find a part # change to prove it.. The cutoff is right around COVID, but I can't imagine it lined up perfectly with a model year cutover..
Will this code throw the SES light, or just be a stored code?
Thanks
Yes light on most likely.  Crank-cam position not plausible seems like it would set from lower end resistance aka the bearings spinning or welding to the crank causing lockup.
you can get a P0016 from an out of round or out of alignment crank with bearings on the way out from rod bearings beating oblong, this is what they are looking for.  I'd expect to see a leak at the seal but not always.  The engine will rotate fine but it'll basically have a wobble in the crank or be out of round and the sensor won't line up to get a signal.  Engine could run thousands of miles like that or die at the next revolution depending on the state of the failed rod bearing (and subsequent thrust or main bearings) either or.  As @newdude mentioned, there's been issues with main bearings and i believe thrust bearings or lifters failing to send metal into the system but the true determination upon investigation is the rod bearing bore diameter if you can get one that's failing before it cracks the cheap powder metal forged rod.  oh, there's also been some piston wrist pin clip failures.
Edited by butzers09silverado
So, it sounds like the "inspection" called for by the recall doesn't mean much, then.
I mean, if the SES light is not on, then the code hasn't been thrown and I get 0w-40 oil put in. Using a scanner to look for a thrown code isn't much of an inspection. It would be a true "inspection" if they were to actually look at the areas where damage might be occurring, such as the crankshaft journals, which requires at least dropping the oil pan. On the other hand, if the SES light IS on due to the P0016 code having been thrown, then it's too late, no inspection needed, and I would likely need a motor instead. Shoulda bought a diesel. Figures.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
