26 minutes ago, Foxglove said:
2025 owner's manual hasn't changed: "Viscosity Grade Use SAE 0W-20 viscosity grade engine oil for the 5.3L and 6.2L V8 engines."
Thanks.  So either they've modified something they refuse to disclose on '25 and up motors, OR more likely, they're just kicking the can further down the road and maybe those years will be added to this mess eventually too.  Either way, it doesn't help with my decision to go buy one anytime soon if still has the same parts and potential issue.
Hmmm....a little bittersweet for me as I have a 2020 with the 6.2L which surprisingly is not on the recall list.  I would have thought they go back to 2019.  I have a scheduled oil change tomorrow at my GM dealer so I'll ask if I should be concerned with this recall.  I suspect anyone with a 6.2 who is not involved in this recall will want to keep tabs on this development.
11 hours ago, Black02Silverado said:
If so then all of their engines would be going bad and GM would be out of business. The fact that it’s happening as early as 1,000 miles or sooner from new states to me an issue with either quality materials or assembly.
It's bearings, correct? Under what régime are mains and rods lubricated? If there is sufficient 'film' then I ask by what mechanism are two parts that are not in contact wearing?
What is the logical conclusion? Parts are touching parts that shouldn't be touching! And what ENGINEERING solution is GM offering?
[Quote from Safety Recall N252494001]
[Close quote]
Oil won't fix a damaged motor so first they must pass inspection and once the unit has cleared? ENGINEERS determined that in a healthy motor more film = more protection...from? Parts touching parts that shouldn't be touching other parts. How do we get more film? VISCOSITY MATTERS.
To me, the fact that the years in question are failing early as in with only 1,000 mile from new on some. This would tell me that manufacturing has a flaw, either in assembly or metallurgy. If the assembly isn’t to specification or the quality of the metal is poor, no oil will fix it. Just a matter of time until it lets go.
How many straws does it take to break a camels back?  Stribeck...what part of the Hersey equation changes between these two motors? (5.3 v 6.2) BMEP x leverage. Keep jacking up the load and lowering viscosity and eventually you cross a line. THE line.
BMEP (More load), stop start (dry starts), taller gearing (lower velocity). Matched with lighter oil, hotter oil and water. How many straws does it take? Does it tell you in the manual to use a heavier oil when towing?
If it were metallurgy they ALL would fail. Robots assemble these things now. Can a robot do randomly OPS?
The ENGINEERS told you what the problem is...believe them. Protect the motor, not the warranty. Or not....
Funny that when a consumer increases viscosity it is the end of the world as we know it. "You can't do that, you will mess up the passive VVT controlled EGR and the AFM/DFM won't work right and break" they say. But it all works just fine when GM tells you to in a motor they didn't spec for it.
People will argue with God to keep from being wrong so why stop with an engineer. They wont win, but they will try anyway.:crackup:
Looked on My Chevrolet app and my 2021 Silverado Custom Trail Boss with the 6.2 shows this recall outstanding on it. Wonder how long before I get a letter from GM or call from the dealer to bring it in. I'm at about 31,600 miles with no issues. I changed the oil at about 1000 miles and have changed it at 6K miles since. I've put some strontium magnets on the bottom of the oil filter(Purolator Pure One or Boss) and cut the last two open after I bought the proper tool and I was surprised at the amount of metal paste on the bottom of the can where the magnets were stuck to. This was just the last two most recent oil changes. Wonder how bad it was on the first couple changes. I also get some pretty nasty looking gunk in the JLT catch can. Can't imagine that helps things any going back into the motor.
  • Sad 1
[Close quote]
[Close quote]
Then explain why it’s just the 2021-2024 6.2’s and not the entire engine line up running 0w-20.  Also include other manufacturers running 0w-20 and now 0w-16 and even 0w-8? Your logic states these all will self destruct. The salvage yards should be full of trashed engine vehicles.
We don’t know what type of inspection is being performed. The only inspection I feel that is going to find the issue is a tear down and that’s not going to happen.
  • Thanks 1
Young man you misunderstand. I have no need to prove anything. Keep doing what your doing. It will guarantee you will get the same results.
I run Honda's on 5W20 for very long service lives. A 1.6 Honda HX is not the same as a GM 6.2 in any way but sharing the idea of being a ICE.  Why keep looking at all variables as if they are not?
I digress. What did GM ENGINEERS say the issue was and what the repair is?
[Close quote]
I said what I said. You are not arguing with me. Your argument is with GM.
Read my posts again. I said more viscous oil prevents parts from touching parts in an otherwise healthy engine BETTER. I stated oil can't fix a damage engine. That if it's healthy the cure was given by ENGINEERS. Yet the only part anyone heard was something I didn't say. Argue is what ya want to do. Not what I want to do.
Grumpy’s never heard of a defective bearing or race. Someone educate him. 🤓
Two things can be true. No doubt some manufacturing defects occurred. But nobody should believe thicker oil will fix that!
I bet GM views the 0w40 as a good hedge against future UNRELATED warranty claims in currently healthy motors. The 0w20 served its purpose shoving these trucks under the CAFE limbo bar. The only thing it costs them to change spec after that is a 10 cent oil cap. Cheap insurance?
  • Thanks 1
But it HAS been changed: part of the inspection, regardless of pass or fail, is to put an insert in the owner's manual stating to use 0W-40 oil in the 6.2L, as well as a new oil cap with 0W-40 on it.
I'll also point out that (allegedly) the LT2 in the C8 shares bearings (down to the part number) with the L87, but the Vettes aren't being recalled, and that 0W-40 has been used in the LT1/2/4/5 since MY 2019 with no apparent issues (and we all know how vocal Corvette guys can be). I'm thinking this is a combination of supplier screwup and fuel mileage greed biting them in the arse. I have a hard time believing that 877k engines were manufactured with whatever this flaw is without someone on the assembly line noticing something was amiss...but then again stupider things have happened.
Edited by carguy1701
misspelling
Oof. Have you had a UOA done?
So now I need to start buying Dexos R 0w40 oil? A quick Google search says they only Mobile 1 makes this. I can’t wait to spend twice as much on oil every time I change my oil.
Prolly don`t even need to do 0w40. One can get his HTHS number up from a 2.7 to a 3..2 to 3.5 with a 5w30 or 10w30. Gotta keep parts separated, as Grumpy says. Me too.😉
I`ve been running 5w30 in my `25 5.3 since 600 miles. No problems. But, it`s not a 420hp 460tq engine. High performance needs higher film strength. Period.
    RyGuy43
    RyGuy43
  • Who's Online   0 Members, 0 Anonymous, 430 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
