54 minutes ago, Sparky134 said:
Will the the engine be engineered to solve the problems plaguing the 2019-2026 Engines?
What problems?
55 minutes ago, newdude said:
\What problems?
Just a guess based on the mentions I've seen on this forum...
Failing coolant control valves (LM2, LZ0)
No start / long crank issues (LM2)
Thrust bearing failures (LZ0)
Timing chain failures (LM2)
Fingers crossed GM has more revisions and updates in the work because the 3.0 is awesome (when it can be trusted).
...was looking to see what the 3 post OP had to say since they've got a personal issue here and 3 different threads they made within the same time period...just today....and then regurgitating that some owners on facebook and other forums have issues which is a small number out of total ownership of 3.0 Duramaxes.
Edited by newdude
  • Thanks 1
i would say it is someone who bought a deisel and shouldn't have, they arenot meant to put around town or excessive idling. the brake thing is a gm problem, some do worse and some do bettter. i put 140k on my 2014 and was expecting the same on the 2020 but only got half of that mileage. a2020 with40k is not that many miles, my 2020 has 120k
Edited by silveradosid
I'll be buying another 3.0l when I replace my 2025 Sierra. I had an issue (engine siezed) but it was replaced and has been fine ever since. I'm spoiled with the excellent fuel economy to swap to a 6 2l or its replacement.
One can only hope that they will correct or have already corrected the issue.
I would only own a diesel if I towed regularly.
On 6/29/2026 at 11:56 AM, Sparky134 said:
Thrust bearing is a very small window.  But nice try.
Turbo oil filter?  Haven't seen any failures.  Change your oil more frequently.  Use a better oil than the factory oil.
For the long cranking, I do know this engine is very susceptible to fuel quality. Watch your centene values and bio content. This isn't a Jimmy that will run off of crude.
Our local stations' (basically everywhere) diesel fuel has the minimum required cetane and is up to 20% biodiesel, ULSD. *My* truck runs fine on it. (When I'm not dumping the local choke-and-puke's used fry oil in the tank to save money!) - kidding.
I'm not sure the documented long crank issues with some of these engines is fuel related, but fuel can certainly always be suspect. Always good to consider bad fuel as a possible cause.
Edited by Atlas
I got a flashback to Smokey and the Bandit.
Problems are blown way out of proportion due to the internet.  The same experiences get repeated over and over again till it sounds like a real problem.   There is NOT an vehicle out there that does not have some issues.  Building 100's of 1,000's of vehicles with 1,000's of parts from various suppliers all over the whole, some quality control issues are going to make it through the process.  The internet is full of misinformation often designed to change readers opinions.
I have had 2 trouble free years with my 2024 Sierra, don't tow anything heavier than a 2026 Ranger NorthStar and mostly a around town. I personally know 3 others with same engine and no issues, 2 are LM2 version and 1 is the LZO, all three happen to be GMC's.  All of these owners are older persons (40+) so that may have a lot to do with it. No modifications, no big tires, suspension hacks etc, just normal use.  One who has a 2021 LM2 has over 100,000 miles and travels estimating projects for the electrical contracting company.
  • Like 3
This happens with anything.
As you stated all vehicles with have a failure rate of some kind. It is expected. I just don't want it to be mine :)
Failure should make things stronger.
Maybe AI will find weak points during design and help build better machines with less failure rate. (until it takes over)
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
    • There's a bunch of tea leaves that you've read, but in any case the delayed timing is unusual. Not sure how that relates to the rich at idle vs. 'normal' while driving.   If you're in this deep, might be worth investigating, and re-learning the sensor. What have you got to lose? Plus, it properly fixes the timing cover leak.
