Is your GMT-900 using oil
1,555 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Quite honestly, I don't think the oil consumption is going to be all that big of a deal when it comes to resale. I predict GM to continue to have higher resale values than Ford and Dodge just like they have in the past. GM already says using 1 quart of oil every 1500-2000 miles is normal and that is the industry standard for many vehicles from what I have been told. If it were really as big of an issue as people try to make it out to be on here, there would be more media attention.
I wasn't so much referring to the oil usage directly. More to the fact that a carfax will show the vehicle history of being in the shop multiple times for excessive oil consumption, pistons, rings, etc.. for a specific vehicle. Would you buy a clean truck with a clean carfax, or the clean truck that has a carfax showing its been menaced with multiple repairs? Or multiple attempts at the same repair... By the looks of the poll here its not ALL 5.3 AFM equipped vehicles that are having issues. So the person that owns a plagued vehicle will likely see less money on re-sale. Just thinking out loud I guess.
I do not believe Carfax is specific as to what kind of repairs are done, though they do sometimes reflect oil changes. Also your assuming there is a high number of trucks out there that have an oil consumption issue. This is not the case. if it were the media would be all over it. I don't see it hurting the resale value of the brand overall.
Edited by RockySierra
......and we all know carfax is junk, anyway. It's just a tool (take the term, "tool" anyway you like).
(GM already says using 1 quart of oil every 1500-2000 miles is normal.) They now say under 2 quarts per 3k is normal. It may not be a big issue to someone, who can afford to trade often, but it sure is for the rest of us. I am not a young man, and have owned more than Chevys in my life. None I've owned, have used this much oil. Ford has quirks too. Sticking spark plugs, that break off in the block, and costs up to $500 bucks for a plug change, if they break. But they did finally revise the heads, and fixed the problem, Chevy just keeps sticking these engines in with no revisions, like nothings wrong. As far as media attention, I doubt anyones going to report on this without proof, for fear of a lawsuit. Resale is the same, because buyers are unaware of the problem, until they purchase. There is nothing wrong with being a die hard Chevy fan, except when you ask you're fellow truck owner, are you using oil? and he denys it out of shame, that his 40k truck is drinking oil like a 250k clunker.
I've read through the almost now twelve pages of this thread....depressing. I only have around 10K on my '11 5.3 and so far no problems. (fingers firmly crossed that I'll dodge this bullet- nothing a few miles won't reveal.)
If, as most in this thread believe, this is an engine design flaw there's really nothing I or anyone can do to avoid it now. If, on the other hand, it can be avoided by using an oil with a very low noack volatility (the percent of the oil that is expected to vaporize when repeatedly heated) http://en.wikipedia....OACK_volatility I think I'm going to switch my truck to Pennzoil Ultra at the next change. In their latest formulation volatility is listed as 6.4% for 5W-30
http://www.epc.shell...01112051450.pdf
By comparison most readily available synthetics are in the 10-12% range (Mobil doesn't list theirs, but Pennzoil & Quaker States dexos certified synthetics are at around 12%--I've been using these) and most conventional oils are just under 15% to meet API certification. I realize oil brand loyalty is almost as strong as truck brand loyalty, but I haven't seen a commonly available oil that can beat Ultra's numbers. If I have any control over my truck's rings and oiling system, I'm going to go down swinging with what I believe is the best oil available. If this doesn't work, I'll be the one trailing a very expensive plume of blue smoke.
Wish me luck
Edited by greywolf11
I have a GMC 2005 Aluminium block 5.3 4WD. It uses about 1 or 2 quarts of oil between changes, I bought the truck new and it did it after a year or two. I use Mobil1. It's
I have a 2000 Yukon XL ,5.3 ,use Mobil 1 and am consuming approx 1 quart every 1,500 miles with 130,000 miles...Not thrilled!
2008 GMC Sierra 1500 SLT Z71 4x4 Crew
90,000 miles
I bought mine used with 52k miles in 2009. I thought I found a great deal at the time. A few months later was wondering why the oil gauge went to zero during a right hand turn. Pulled the dipstick and not a drop on it!!! WTF!!! only 2600 miles since the last oil change!! had to add 2 quarts. since then I carry two quarts under the hood.
I've also owned only GM. never had to add more than a quart between oil changes even on my '73 C2500. I put over 200,000 miles on my 93 Sonoma (4.3L) and never had to add any oil between changes.
So far I've been keeping an eye on it. Pretty much adding a quart every third tank of gas. Ridiculous! I've been using Valvoline full synthetic since I bought it. One good thing is no smoke so at least its not completely embarrassing.
Since I bought it with no warranty I haven't tried the dealer for any fixes. I've been keeping tabs on several forums to see what others have done to get the problem corrected. So far, and almost 30k miles later, it seems the only fix is a near engine rebuild and to disable the AFM right after. Anybody see another solution?
Over the holidays took a trip to Florida. Did an oil change before I left so I know it was full. Round trip of 1100 miles. When I got home checked the oil and nothing on the stick!! Had to add 2 quarts after 1100 miles. Time for a new engine?....ugh.....
My plan is to start shopping for a crate motor. I'm not a gear head but I've done a few engine swaps. Though this would be my first on a daily driver that still has another 2 years of payments. This is not going to be very enjoyable.
Anybody have suggestions/sources for a 5.3L crate motor? Do I need an AFM compatible motor? I found a 5.3L HO on Jegs but would it be a bolt in replacement? guess I'll call Jegs and see what they say too.
90,000 miles
I have an 08 also, 41,000 miles and no oil usage (yet)
Amsoil 5/30 since 1,000 miles
Sevice manager @ GM dealer told me they had decarboned the rings on a few 5.3's
I'd power foam that engine before replacing !
BTW you are still under power train warranty, good luck
hillbilly and greywolf, y'all are right I think. I've had Chevy, Ford, Dodge (Dakota, not full size), and it's hard to say which I like best, except for the Dakota, which I still have - it has been the best vehicle of any in my many years of driving (over 50!). It is a '93 with the 3.9L engine. My last Chevy was a '96 5.7L was it? The old 350. Now, that was a tough engine for sure. I guess the 5.3 is made on the same basic foundation (?), but to me, using oil is not good, not matter what GM says is okay. I mean, wow, not 1.5 or 2 quarts in 2,000 or so miles! I presently don't have a 5.3 engine, but this kind of information helps those of us who are presently looking to trade. I hope all goes well with your 5.3s.
My 07 aluminum block uses .5-1 qt every 3k, I had no idea these trucks did it before I bought it. I just buy an extra quart and keep it in the back seat (Mobil Super High Mileage). I have seen no ill effects as of yet I have put almost 14k miles on it since April when I got it, now at 73k.
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
    • It costs $5,250 for the Yukon Nightfall option (black wheels, emblems and illuminated black GMC grill badge). What a "deal".
    • I keep getting the above error message on my 25 Sierra.  If I reset the infotainment unit (via the phone hang up button) it will work again for a day or 2.   But I dont want to do have to reset  all the time. Works fine in my 2023 Corvette. On both vehicles I connect wirelessly.   I have a Google Pixel 10 Pro XL, phone is up to date.  Any Ideas.  See attached
