10W30 in a 2011? Seriously?
I took my 2011 Avalance in for an oil change on Thursday. This was the first oil change they have done since I bought it thus it was free. After I got back home I noticed it said 10W30 oil and not 5W30 as specified in the owners manual. I drove back over on Friday to ask what happened assuming it was a typo and was informed by the Service Manager that "5W30 is a little too light for him so they use 10W30. But if you're worried, don't because we used Dexos and it does the same thing at any weight".
I just shook my head, explained that was the last maintenance the morons at Champion Chevrolet Houston would ever do on my truck, went to Wally World for Mobil1 5W30 and an new PF49 filter (yes, I've done dozens of oil changes in my life but assumed I could trust the dealer - some things never change at the dealership). The oil and filter have been changed but I wonder how many folks get this?
Additionally, I noticed a huge difference when AFM was kicking in when it had 10 versus 5W...could there be that much of a difference or was it in my head? Could it be Chevy is recommended the dealers use 10 due to the issues they've had with AFM and they know 10 will reduce the amount of time it actually works thereby eliminating some of their potential recall headache? Not trying to start a conspiracy theory here but trying to understand why a fool would ignore the manufactuers oil requirements on a new truck?
  • Replies 58
i run 10w30 in everything i owned.GTX,i suggest you start doing it yourself.They always use cheap oil and cheap filters.5w30 is thin to begin with and only gets thinner.
Then why is it what the owners manual and gm calls for?
I use 5w30 in my 2006, but everything else gets 15w40... and no issues yet, I wouldn't worry about it. Being a dealership though, I would expect them to do what the book says, I would have made them pay for the right oil and made them change it.
At operating temperature (100C) a 5W30 and 10W30 (or a 0W30 for that matter) of the same brand and type oil (dino or synthetic) will have almost identical viscosities. A 0W oil will get to moving parts faster on cold startup than s 5W oil and a 5W oil will get to moving parts faster than a 10W oil. Remember a cold start is any start where the engine temperature is not up to full operating temp (~200F).
DEWFPO
I use Mobile 1 full synthetic and change my oil twice a year no matter what my oil life system tell me. I change it in the spring and again in the fall. Spring time oil change gets 10w-40. Fall time oil change gets 5w-40. Does it make a difference? Who knows? But it's what I've done for for as long as I can remember and have never had a problem. My 2 cents!
The only dexos 1 oil out there is in a 5w-30 weight. So in reality the dealer didn't install what is supposed to be installed per GM for 2011 and newer vehicles.
Would it hurt anything, no as stated above there isn't any difference in the oil at operating temp just at cold start up. If a GM dealer isn't going to follow GM requirements then it kind of make one wonder what else they are doing in the shady area.
Considering your newest truck is a 2000 with a 5.7l engine, I 10W30 is fine. I would probably run 10W40 in the summer. But for the new engines with tight tolerances, it's 5W30.
Has nothing to do with tolerance. Hello piston slap in the 2012s?
It is fuel economy with the lighter oil.
I would have demanded they follow the book and then called gm and let them know what the dealer is doing.
I considered doing this but at least they were honest and actually documented it on the service ticket thus I have proof. My attitude is I will never go back to Champion Chevrolet as they can't be trusted to service the vehicle in accordance with manufacturer specifications. Would hate to go back for a coolant flush and discover they felt it was too green so decided to use Root Beer instead! Morons I tell ya!
As for those who say no difference with 10W40, I looked when I was at Wally World and 10W30 doesn't even bear the Dexos logo on it so how could it be used and the vehicle not be denied a warranty claim if something went wrong with the engine? I'll stick with 5W30.
looking at Mobil 1 web site 5W30 is actually thicker than 10W30 at operating temp.
And they have the same cold pour point.
. SAE Grade 5W-30 Viscosity @ 100ºC, cSt (ASTM D445) 11.0 Viscosity, @ 40ºC, cSt (ASTM D445) 61.7 Viscosity Index 172 Sulfated Ash, wt% (ASTM D874) 0.8 HTHS Viscosity, mPa•s @ 150ºC (ASTM D4683) 3.1 Pour Point, ºC (ASTM D97) -42 Flash Point, ºC (ASTM D92) 230 Density @15.6 ºC, mg/l (ASTM D4052) 0.855
Mobil 1 10W-30 SAE Grade 10W-30 Viscosity @ 100ºC, cSt (ASTM D445) 10.1 Viscosity, @ 40ºC, cSt (ASTM D 10W-30 Viscosity @ 100ºC, cSt (ASTM D445) 10.1 445) 63.2 Viscosity Index 146 Sulfated Ash, wt% (ASTM D874) 0.8 HTHS Viscosity, mPa•s @ 150ºC (ASTM D4683) 3.0 Pour Point, ºC (ASTM D97) -42 Flash Point, ºC (ASTM D92) 232 Density @15.6 ºC, g/ml (ASTM D 4052) 0.859
The "lighter" will give you lightly better mileage. While it is not really that noticable to the end user, it has a big impact on how GM can meet the CAFE numbers. The OP is from Texas, not sure how much below freezing temps he gets there. If none, then it is a good idea to use 10w30.
Keep in mind that GM wrote the manual for the entire continent. They have to give the spec that is best for everyone.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
