And now my pac harness is installed for the steering wheel controls
Sent from my PIECE OF CRAP DROID X2 using Xparent Red Tapatalk 2
Ordered new tires. They only had 3 in stock so should have them put on next week
275 bfg at's :)
Ryan
Nope going black walls, I am over keeping the white letters clean. Did that in my 2000 for years
Also my truck looks to have suffered some minor damage from the valet SOB! Nick in the doorhandle
Ryan
Ryan
that idiot, do you have any touch up paint?
Thinking about an Airaid Jr for my truck with the SynthaMax filter.
Yea after I go back out to finish washing it I am going to try and fix it or at least blend it
Ryan
Ryan is your truck leveled or stock? I figure I'll be getting tires soon enough (almost at 34K!) and I'd like to take it up a notch. Get pics.
Truck... nothing. But did complete "phase one" of my dirt bike resto. Will be having my frame sand or walnut blasted soon!!!!
Starting my mini bak rack tommrow!
Sent from my ADR6400L using Tapatalk 2
2" RC Level Kit
The 275's are 33.2" tall :)
2" RC Level Kit
Maybe we're thinking of different 275s then- I might do 275/65/18. These will fit stock and be just a bit bigger. Most likely the General AT2s like I had on the Taco but I also really like the new BFG Ruggen Terrain. The photos don't do justice to how aggressive the tire actually is.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
