I call dibs when you part it out!
Sent from my LG-D800 using Tapatalk
Better come get it before I torch it. I dont even see how that happens. Gonna see if the shop can do anything about it.
Did see a lifted Taco that looked pretty nice. Ehhh I want full sized. Can't afford full sized. Damn...
Sent while drinkin' a cold one...
Installed this after work today, rather impressed with the installation if I do say so myself.
I feel your pain bud. I noticed when I put my stock blocks back in that the base was cutting into the axle over time. I bet that I what happened to yours
Edited by zach1990
Assuming rear main oil seal. Replaced oil pan gasket when I put motor inqaveqyqy.jpg
Saw that and basically just gave up walked inside grabbed a beer and posted this. Done with this damn thing. Time for a new truck. Looking as I speak...
That's a bummer never seen one do that before.
I may have over torqued the u bolts causing what you're taking about. Hopefully it won't cost much to fix cause that tranny drained my account
May be able to wield it. Let me know what you find out cause mine was cut into pretty good
That's what I was thinking. I'll ask the guy at the shop when they replace the pinion seal and pull the cover to see what's making the noise back there
Headlights only
Light bar only
Kinda surprised by the light my cheap little 20 inch bar puts out
I just changed the oil in the Ram 2500 we have. The oil filter location on the hemi kind of sucks. Oil drips all over steering linkage
I'll be buying the center consol lid, hood release handle, windshield wiper fluid hose, and front brake pads from Rockauto.com tonight. Great prices and shipping costs, I definitely recommend this site.
These little details will be on top of the a/c refurb that I did in April. Hopefully in July I will be able to purchase new shocks, Bilstein 4600's. I will replace the rears myself but I'm not sure about the fronts, I hate paying out the butt for labor but I may not have a choice.
Edited by white1500
Fronts are easy. Requires 2 wrenches and patience up top and a single socket on the bottom
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
