That g8 is actually up for 18900. Bet I could have them knock some off if I really wanted it. That dealer over prices everything anyways
Sent while drinkin' a cold one...
Changing spark plugs in my 78 jimmy. I got the one in the far back passenger side out, hard part is trying to get it back in. My back is killing me :(
Oh yeah update on my truck. Took it by the shop to see if they could weld those cracks. Well he pointed something out to me that made my pocket shrink. I guess my impact is too powerful cause I actually bent the tube and bent the spring perch from over tightening the u bolts. Got online when I got home and found a 14 bolt about 4 hours away
http://westmd.craigslist.org/pts/4453827847.html
Getting torn down and rebuilt anyways so I don't care if it doesn't even work. As long as it isn't bent and rotted out
Edit: damn he sold it. This is a hard one to find
Edited by rdnckhntr94
No. The spring stays in place while the shock drops out tbe bottom
So lift the truck and let the suspension droop, then remove the bottom bolt that holds the control arm and strut? Then remove top bolt and slide out.
All this without any worries about springs?
Did a Frontier similar to that, it was so easy. Just a few bolts and a few minutes.
2 bolts on bottom side of lower control arm and then the stud up top
2 small bolts for 2wd trucks. 4wd trucks have just one big bolt on the bottom and the stud in the top.
And just jack the truck up, put jack stands on the frame, and let the front suspension droop. If need be, put the jack under the control arm (under the ball joint) to push it up so you can tighten the top stud nut
Trucks are so much better to work on. I'm taking my car in at 8 or 9 years old for the serpintine belt. No friggin way I'm even going to try to get in there.
all spark plugs are out, SP holes are soaking in marvel mystery oil. Gonna put a battery on her this weekend hopefully she'll fire right up and run!
Oh and got the dead mouse out of my coolant tank haha
The top I dont remember the sizes needed. You need a small one like maybe an 8mm to hold the stud while you turn with like a 14mm or 15mm. The stud will turn if you dont hold it. It is attached to the piston inside the shock
What had me worried was the thought of having to compress the springs. But if its just a slide out process I'm very relieved since its just another job doable in a garage.
Yep, takes a socket, couple wrenches, jack, and 1-2 stands
Chris, didn't you say you were looking at doing a hybrid axle swap in your truck? I finally found the RPO code and it's AXN. I need one now, so let me you if you find one for me lol
    • No ETA is available for that engine at the moment in the GM system.   I would start at the dealer.  Try and talk to the parts manager or service manager and see if they can start a CX Connect case and get an ETA from GM on when engines may be available.  If they just check Parts Workbench and say "no eta", they aren't trying hard enough.  They need to do a CX Connect and chat with DPAC to find the ETA.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • $4.26 85 oct
