I like #1 the best
On a side note the Ford F150's with projector headlights look awesome IMO. Look really clean and look really good on a silver truck
4 but don't bother with hid highs the warm up period makes em almost useless when switching back and forth for traffic. People hate trucks with hids in just the lows anyway. Ask me how I know lmao.
I like #1 the best
I always thought they looked like a bass
This came yesterday. Hoping to do an install with pics tomorrow to put in my build thread.
I need some help choosing some headlights
Your input will be appreciated and what do yall think about hids all the way around( high beams, low beams, fog lights)
I vote 2.
Skip aftermarket headlights. They're cheap china junk with poorly designed reflectors.
Got to haul around some signs for a ceremony that were having next week. Not much of a load but at least it wasn't the replacement broom stick from before...oh wait that was in there too...oh well.
Hmm I'm wondering if that affected anything like air flow? Lol those are my old cabin air filters. Gross...
Maybe a little restriction.... :lol:
Definitely more air flow now. My driver's side vent barely blew air out now it's a lot better but not sure why it's much weaker than all the other vents
I think the driver's vent is the last to get the air from the blower. Mine is the same way. When i don't have anyone riding with me I tend to close off some of the other vents and it increases flow quite a bit.
Well it seems like the first one is very popular but if I go with this one I won't buy it I will take apart my factory lights and paint them and remove the amber lenses, I like the first ones but those amber lenses have to go.
How do u get to those
The filters? 03 and newer do not have them.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
