Sometimes the rear doors on mine won't fully latch at the top. This makes for more wind noise as well as rattles on bumps. Just give each door a tug with the front open.
As for the ISS clunk, congrats on making it this long without it. :lol: But looking at it won't give any indication. Besides, the clunk comes from the slipjoint underhood by the exhaust manifold. :P
I've found that if I slam the ext cab doors pretty good I usually don't have any trouble with noise from them.
It's not a latching issue, it latches tight without needing to slam the door. Sounds like the rattle is coming from the lower portion of the door. I thought it was the rear seat when I heard it driving, but then realized it gave off a "buzzing rattle" as I closed it.
The rattle in the dash is more of a buzz too, starts when I give it a certain amount of throttle taking out. When it's colder it will do it over joints in the road as well. It may be the bracket in the dash. Neither of the noises is affected AT ALL by the radio, which I thought was interesting.
The shaft issue I noticed hitting bumps turning, I realize it could be something else. Just a clunk when I hit a bump right.
Picked up this mobile air compressor from Amazon. Throwing in the toolbox
Ryan
Ryan
How much. Im kind of in the market for one, but I am more wanting a compressor and jump box combined
I forget the brand but they had a combo last yr didn't buy and now they are no longer made. I paid like $54 with free shipping on Amazon
Ryan
After a long day at work and having to go to class i left my passenger side window open by accident and it rained while in class. So i guess i could say i cleaned the passengers seat and the map pocket on the door.
Walmart sells some pretty loaded Schumacher brand combo jumpers. The one for $140 has everything and is rated at like 1200 amps I think. I had one of the Schumacher smart chargers and it did awesome until the 6 or 7th time I dropped it. (Now gets stuck at 75 percent readout, just keeps charging forever.)
Keep saying I'll replace it but it is basically a dumb charger but still works
I did that on my 325is one time when I had it . Luckily I had just put on waterproof seat covers!
Sadly i do not have water proof seat covers. I am just glad nothing got stolen considering i was parked in a not so nice city.
Dropped her off at 8am for the 6 inch lift kit to be put on! Can't wait to pick her up!
Still waiting!
Sent from my LG-D800 using Tapatalk
Still waiting!
You and me both bud! Can't freaking wait! Should be ready around mid day tomorrow! I'm selling my pretty much brand new shocks if you or anyone wants to buy em?
What do you have and how much?
I wanna say there Monroe sensa tracks got em from advanced auto. I'll have to double check. I got em when i came home from school in May. Hmm haven't even thought of a price yet to be honest with yah!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
