You have no room to talk. God damn RB
No no, just in more debt than you lol
Went to Lowes and spent over $500 buying insulation and can lights, base board, and a exhaust fan that has blue tooth that plays music off your phone or iPod can't wait to install that bad boy. Checked the status and my lift kit will be delivered tomorrow.
That sounds like a bad ass exhaust fan. I want one now! Haha
Maybe. Im about $30k deep
Gears are in it my rear brakes were shot so they're doing that now those are my buddy's 40 inch mud grapples lol they look sweet on there
Not as much as Sarah but got this done, oh forgot since tapatalk did upgrade I can't post pictures with it!!!! I'll get them later. :jester:
How many bodies can you fit now Jim? :jester:
A lot!!!!! That is what one of the guys who helped me said man you can haul a lot of people in there!!!! Its 20 cu ft. I can't wait to make the first trip using it next month to see how long it takes for the wife to fill the bed this time. I love my wife but she has a bad case of bargain hunting, so I hope to have made that a little easier now. :jester:
Does it sit in the bed rails? Any links to the product? Thanks
Ryan
Over the past week I clay barred both trucks. This never cesses to amaze me what it does for the feel of the paint. Followed up by wax on both!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
