Been pretty mild the last few weeks. Got up to 37° a few times. Hit 12° a couple nights back.
Better than -14° to -17° (depending on which thermometer I looked at) on Valentine's Day, 2016 I guess ... :thumbs::lol:
Edited by Jsdirt
Noticed I have a headlight out. Which annoys me seeing as how I just replaced both headlights in August not even 10k and one went out. This is why I replaced both last time when only 1 was out, I don't want to spend 1-2 hours tearing half the front end apart to replace a stupid bulb! I guess this time I'll pull the battery.
There's always a first in a domain, I just repaired a cluster for a 2005 DuraMax six speed manual standard cab long bed. See the 5K Tach... I'd say it's a pretty rare truck. High beam indicator didn't work, left blinker bulb was missing, broken selector switch for odometer display burnt background bulbs and a bunch of other stuff. To my surprise all motors worked good.
Edited by Coby7
A few months back somebody gave me an old defective cluster, I didn't realise it then that it was an 06-07 classic and put it aside. This morning cleaning the shop a bit I came upon it and said to myself what the hell lets see if I can resurrect this baby and put it up for sale.
Some barbarian had been into it and nothing worked. He had stripped The idiot LEDs for CEL, ABS, Seat belt and emergency brake. By doing so knocked off a few components, one in the high voltage circuit supplying the odometer display, background bulbs were cracked and burnt and most of the gauge motors were bad. I scratched my head and wasn't sure I wanted or felt like doing this this morning. But one by one I tackled each obstacle and when I got the odometer display going and saw it only had 214502 Kms then I really wanted to get her going. Replaced all missing components and stepper motors and LEDed in cool white. It turned out pretty good and every thing works, I think. Need a truck to test it in now.
Edited by Coby7
I miss my gmt800 lol
Sent from my SM-N920V using Tapatalk
I don't
I had a guy ask me what I wanted for mine. I told him $20k. "It's probably worth half that." You asked me what I wanted for it....
That said, the whine in my rear end is definitely getting worse. Looks like I'll be on the hunt for a 12 bolt axle.
Sent from my SM-G920V using Tapatalk
Edited by kstruckcountry
Just had an older guy drop in, didn't call or nothing. Fixed his cluster just the same lol..Then sold a 2004 Honda Civic FOB and a 2002 Silverado FOB
Good luck finding one. All the ones I found locally they wanted $1k+ and most of them had 120k+ miles on em
And a new unit from GM with disc brakes like Ryan's truck is about $3000 from the discount sites. Not worth it. You can build a strong 10 bolt for that cost.
Seems like you have a really good thing going with these clusters.
Except I don't normally work on others except 03 to 07 and this afternoon again unannounced a guy drove from Fredericton 2 hours away because he heard somebody in Moncton fixes clusters and his truck was a 2002. I didn't turn him away and I fixed his odometer display but sure wish they would call first. Asked the guy for $20 and he gave me $50. So 2 of the 3 clusters I did today were unannounced. It kinda stirs my soup a bit...
Don't complain about (good) business. :)
Sent from my SM-G550T using Tapatalk
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
