You don't want to keep electronics in your vehicle. The change in temperatures and humidity are horrible for them. Especially these cheap Autocals.
No because heaven knows there's no electronics in these trucks. lol
YOU also know, you can change your signature in your cell phone too unless you are paid to advertise for SamSun, then you're good. Is that the one that catches fire?
Edited by Coby7
Lol
My old bully dog sat on the a-pillar for 3 years, and my Diablosport inTune i2 has been in my glovebox for almost year with no issues. I don't see anything wrong with it
Sent from my SM-N920V using Tapatalk
You also don't have 90 days of 100 degree weather
I've just seen a bunch of iPods, cell phones and tuners get messed up from heat. Usually the cheap LCD's pop and then you have streaks of black. That really doesn't happen anymore on newer devices. But these cheap hand held tuners are just that cheap.
My autocal has been in my truck since 2010. No issues
More than likely it'll be fine. But I've seen way to many devices get destroyed by summer heat and winter lows to risk it.
Helped my brother in law put 4 new speakers in his reg cab truck. Might as well do something useful while I'm up here in NJ. I think next we're going to get his tractor thing set up for the 5-10" of snow they're predicted to get over night.
This morning I received a cluster for repair in the mail. This guy said he ordered motors and LEDs on ebay and installed them, put every thing back together and nothing worked. It looks so easy on YouTube so people try, why he didn't stop after ruining the board after the first motor is beyond me. The motors he put in, 2 were bad maybe because he overheated them I don't know but they didn't work. 4 of the 9 background LEDs were backward. He had bridged traces by applying too much solder. What a mess. Anyway got her going but took me 3 hours instead of 45 minutes. Here are a few pictures of before and after, he wanted blue signal arrows for some reason. I aim to please.
Edited by Coby7
my favorite LED light swap was headlamps, and dash. I need to add a resistor for the dimmer part, but it is comparable to my dad's 2016.
well worth it. Gauges last longer, no hot bulbs.
I chipped about 200 pounds of ice today, out of the back. Not sure the photo captures how thick some of it was.
The first 40F in a while, taking advantage. It was 9F just eight hours ago.
banging on the bed brings a gong church bell type sound. I made it tough... making a frozen lake is just a byproduct I need to live with.
This guy came over wanting a FOB programmed for his 2011 Impala until he could get enough cash to get a remote starter installed. I said no problem but before I started the programming I looked at his RPO list and noticed it already had a factory remote start (AP3). So not telling him I programmed 2 FOBs even though he only wanted one. Then pulled the key out while he's sitting on the passenger completely clueless, I locked/unlocked the doors then I locked and remote started the car. You should have seen his eyes, cheapest and fastest remote start install he ever saw lol. He bought both FOBs lol. An other happy customer.
Edited by Coby7
How in the world did he not know he had remote start? Had to be great watching his face.
I think he purchased the car at an auction ( Just came with a key ) for his wife and since one of his buddies had the same car with no remote start he assumed his was the same. His comment and this is no lie, '' The wife is going to be so happy that she can warm up the car before getting in it in the morning, I may score tonight '' As for his look it was priceless!!!
Edited by Coby7
  • Like 4
Guys, I was wondering I bought my truck used as U probably all know by now so I'm not really sure what's normal. For instants the steering wheel buttons, only one of them is lit at night so I was wondering if this is normal or they should all be lit?Right now only the answer button is lit.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
