Now that's a good place to be. :thumbs::cheers:
Ran my dog to the vet... 3 seizures within 24 hours.
Sent from my SM-G925V using Tapatalk
Sorry to hear that Sarah. Hope he's ok.
I just missed you. I was down for 4 wheel jamboree a couple weekends ago, but you wouldn't of had them installed then. Those 275/70/18's never rubbed with your 2" level and factory mud flaps did they?
No rub
Ryan
I took my truck in to the dealer to see what it's worth on trade in cause I need a bigger truck to pull my 5th camper I mean 13 000 lbs is a lot on weight for a 1500 5.3. But I hate to say it I think im leanig towards a Dodge I really miss having a manual transmission and Dodge is the only one to offer a stick and I can buy a Dodge Cummings slt with 6 spd manual way cheaper then a Duramax with a boring automatic. But I'll always have my old trusty 94 Chevy I'll never sell that old girl and its not that I hate GM but I do really want another stick shift and I just feel I will regret it if I buy another automatic I just don't think I'll be happy I just plain love manual transmissions.
The cummins with 6 speed gets less power than the auto version. Or at least used to
Still is. Torque is like 60-80lb. less
There is no transmission on the market better than the Allison, IMO.
Sorry to say it, but the Aisin in the Ram 3500 trucks is an exact copy of an Ally (supposed lawsuit over it) and Ford's torqshift tranny is no joke either. The Allison has competition these days.
That torqshift trans is rated to some ridiculous number like 1400 lbs of torque
But 1400 according to ford is about 700 from a GM engine
Eh I'm not sure about that lol.
My buddy used to work solely on powerstrokes (which drives me away from them, always heard horror stories) but he said he's never replaced a 6 speed torqshift trans while he was working there at the Ford Commercial delearship. Now 6.0, 6.4, and 6.7 PS are a different story lol
We used to have a 6.0 excursion with the 5 speed torqshift
I'm referring to the new 6R140 torqshift models. Don't really read up on the 5R110 model. Now back then, GM definitely had the upper hand for sure. The LBZ was awesome then strapped with an Allison 1000 you just couldn't beat it
We never lost the trans, list the #4 and #7 injectors. Transfer case literally grenaded on the freeway in the ram 2500 gasser, throttle body in the 04 F150, and melted fan relays in my Sierra. We dont have the best luck
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
    • What are the conditions of this rich idle? Warm or cold engine? Run time? Does every idle look like this or only sometimes?
