So with the cooler temps that we are finally seeing...not cold as this is South Georgia...my temp gauge is telling me my thermostat is screwed. It takes a looooong time to come up to full operating temp and if the truck sits any amount of time the temp of the engine drops off quickly. Guess I better get myself in gear and get to that repair pretty soon.
I've hauled several 9,000lb loads the past few nights, 200 miles one way each time. Transmission never gets over 150, and coolant stays right at 205 the whole time.
Oil pressure usually sits around 55-60psi.
As the miles go up, so does my satisfaction in this truck.
That's a real good temp to be at. Mine tends to run 90°-120° over ambient, sometimes more depending on how many hills (and how steep) I encounter. Got a tranny full of Amsoil, and the towing package (factory trans cooler).
Only twice in 8 years have I seen it go over 200° - first time was on a 93° day according to the mirror thermometer, going up a 12% grade at 50 mph for over 5 miles with about 6k lbs. behind me. Was a nice, straight road. The coolant temp also came off of dead center on the gauge, and was headed quite a ways to the right. Truck never missed a beat though.
Second time was this spring - had over 7k on, and climbed a MUCH steeper grade for about the same length with many more twists and turns. Kept at 45 mph, but on a much cooler day. Coolant temp only went up slightly.
Both times the minute I crested the hill, the temps dropped fast.
I have experinced Stock gauges are not accurate for coolant and oil pressure.
With my Edge Insight CTS is coolant @ between 180-210 while stock gauge stays at 210. Oil pressure range is less on stock gauge also.
Yeah that's pretty much a given. Good for reference though.
Vacuumed the interior and witnessed a wreck.
Was pouring rain (typical Florida monsoon lol) and there was a Camry (it's always a Camry, have you noticed?) tailgating me. I turned into my neighborhood. Guy pulling out of it thought there was no one behind me, since the Camry was so close to me he probably couldn't see it, and pulled out. All I heard was the loud bang. Luckily I was only doing around 30 because of the rain so I checked and none of them got hurt.
Don't tailgate!
Drove my a lot and looked on area GM dealer sites, no one in tulsa area has 2016 half ton trucks yet. Off for several days, was hoping to get a look. Ran by honda dealer last week to see new Pilot, one on the entire lot and parked inward toward the door(how a dealer does when showing or selling). Wonder what the hold uo for so many brands is, are the trains still backlogged? All three vehicles are supposes to be readily available by now from what I understand. Havent seen a new cruze yet either, isnt that supposed to be on the lots?
Edited by SnakeEyes
Sent from my SM-G925V using Tapatalk
Looking good Sarah. I especially like that you chose to have the white letters facing out. :thumbs:
Yep - that gets a thumbs up from me too. :thumbs::thumbs::thumbs:
Drove it 2 miles round-trip today, to change out tie-rod ends on a '66 Ford 5000. Getting my money's worth out of the Viair system. :)
Had my tow mirrors wired in correctly. Everything works perfectly as intended by GM now.
Now to save up for some wheels and tires...
I-65. Fuel up like 40 cents in Indiana in last week.
Where in Indiana?
Ryan
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
