Need 29's
[emoji107]
Need more lift and axle for 37
Sent from my SM-G925V using Tapatalk
37's killed the peppiness in my 02, stick with 35's, I was messin around lol. 37's are just huge, but pretty awesome
I need one that won't rust!
[emoji107]
Stick with 32's
Picked up a miter saw from a buddy to cut some flooring tomorrow, as well some concrete patch and sealer as we've finally gotten some good fall weather for getting the pre-winter work done outside.
Did some high speed off roading some moron saw me trying to pass him(legally, two lanes same way, merging into one a block later) and when I got beside him he swerved into me, trying clearly trying to sideswipe me so I had to drive off into the ditch instead of having a wreck, time to get a dash cam.
Some guy was pulling out from a gas station as I turned right (exit was about 100 ft. from road I was turning on to) and I almost ran into him going about 20mph. Wish I did cause I have a bent bumper and broken headlight mount from hitting a deer so he could have paid to get that fixed as well lol
I had that same thing happen a few months back. Tried passing someone on the left, legally, on a similar road, and the guy drove into the side of me. Ended up getting new Westin wheel-to-wheel step rails, a new power/heated/LED t/s mirror, and all the scratches on the passenger side fixed - insurance covered it all.
Guy was 67 years old. I would have let it slide, but he was a belligerent dick.
    • How did all that extra get added? AI bot!
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
