Show your tractor
timdan94
Just starting a thread to see what everyone has for tractors.
Here is mine a 2010 kubota bx 25 i have a 48 inch tiller, 6.5 ft snow plow that clips onto the bucket. and a 14 inch single bottom plow.
  • Replies 43
It's not "mine" but I have a feeling I'll be spending more than a few hours in it next summer. I'm not an IH fan, but if I'm going to run one, it might as well be brand new!
And I already have quite a few hours in this one...
Just for mowing and general work around the place - best money I ever spent.
I'd love to have a small tractor like those shown. Even with just one acre, I could pit some hours on it.
Larry
That snow plow sounds very handy. Ive been looking for a better way to move snow but must be missing something. Ive not seen the clip snow plow thing. Can we get some pictures of that? Thanks!
Ours: Kubota L4400, 60" reverse turning tiller, box blade. Landscaping and BIG garden.
Bought for dad: Kubota L2800, 5' mower and regular 5' blade. driveway maintenance, mowing and hauling logs.
Spent lotsa hours on JD 4010's and 4430's. Refurbed a 4480 but never got to drive before the farmgot sold :(
Everything diesel. Don't beleive in gas tractors ;)
Got the manual tranny on the L4400 because I figured Id need the few extra HP's for that tiller. Wow will that thing till but Kubota's HST tranny is pretty handy.
Weird thing about my L2800: I think they are listed as a 3 cylinder engine but mine has 4! Bought new last year or the year before. Dad is loving it.
Had the L4400 for about 5 years now. Other than complete fluid change, been running great!
http://bxpanded.com/index.php?l=product_detail&p=24
I copied the idea... All I did was weld a piece of angle iron on to the a frame of a truck plow I bought and bolted a piece of chain to the back of the A frame. I use a chain binder to keep it on the bucket.
Ah. Thanks for the info! At that price I can see why you rolled your own!
Wonder if dad's old ATV snow blade....hmmmm
  • 1 month later...
  • 1 year later...
I use this for mowing and snow blowing.....works great. I have a huge driveway and lots of sidewalk. The walk behind works for the walks.post-133279-0-01440800-1415489663_thumb.jpgpost-133279-0-90299500-1415489693_thumb.jpg
  • 1 month later...
Here's my little guy loaded up to head to my MIL's for some pre-holiday cleanup:
Having a small tractor makes life so much easier. My one wish if I were to do it again, would be to get a TLB/mid-mount mower combo rather than a just a loader/mid-mount mower.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
