275/70/R18 BFG All Terrains - Photos
RyanbabZ71
  • Replies 34
Looks good Ryan! Best tires out there IMO, mine are quiet enough but you can tell they are there. Everyone's got an opinion, but I much prefer white letters showing, makes everything look better people don't even realize. but it's not a big deal.
I don't mine either way but I like the black walls better because they are easier to keep clean. I cannot stand brushing the white walls been there done that
Ryan
looks good! any other pictures??
What others would you like? Full truck shot? Didn't do that yet as it has been raining grrrr
Ryan
full shot would be great. im am having the hardest time picking a tire size. I dont want the 33.1 (275) to be to big. I also found the 265-70-18 that has a 32.6. then i cant decide if i want a P tire or LT. that 265 comes in a P tire but my other choices are limited to LT.
Here are a few
Ryan
I know you have the 6.2 but can you feel the added heavyness???
A bit yes but it's more of a solid feel. Definitely how I like a truck to feel. The stock tires are to "soft"
Performance wise I didn't lose much it still gets up and goes
So far in about 50 miles today it appears I an down .7-.9 mpg
Ryan
I'll be curious as to how they workout for you. I've got low mileage on the truck, but she's already 5 years old, so I'll probably consider tires next fall and well have to do some looking around.
Looks great!!!
I love BFG at's. I run the white letters out on my summer wheels and on the stockers I run the stock size with blackwalls for the winter.
I think if I go with this size I'm going to throw my 3.73's from my last truck. I think this tall of a tire is going to make me really hate my 3.08's that I'm already unsure of.
Ryan, Do you have a lift in the rear as well or just the 2" level in the front? I'm looking at getting the same tires and want to make sure I won't have any fitment issues. Thanks!
I have 3" rear blocks but they would fit without them
Ryan
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
