The 9 loves boost though. There are guys running 20 lbs on a stock block and pistons. There is a lot of support for LS motors
Sent from my Samsung GS4 using Xparent Red Tapatalk 2
Look at my 04's signature....... nothing is stock in that engine lol. You can build whatever you want with an LS.
Personally if you are straight boosting it I wouldn't pay a premium to buy an LQ9...... just get an LQ4 from 05 and newer and go nuts. Cheaper and will do anything you ever want to do until it implodes....... at some ungodly level of power.
I just went forged to try and prevent picking up the pieces in a quicker time frame.
Just to reiterate. The only difference between an LQ4 and a LQ9 is the piston itself. Heads, cam, intake, injectors and anything else is identical.
LS2 heads work pretty damn good on these motors as do LS6 heads. Same casting, just dofferent valves and springs
Sent from my Samsung Galaxy S4 using Tapatalk 4
Or any 4.8/5.3 truck heads from 07 on, plus their intake manifolds. You just have to deal with the fact you have only steel intake valves and regular stainless exhausts lol.
Put 243/799's on a LQ9 and enjoy your iron block LS2.
Danny, if it was good enough, you wouldn't be wanting to replace it with a 6.0
I think I would definitely enjoy 50+ more hp. But it's already easy to roast em with this engine. Most people with trucks and some cars don't realize how easy it is for my basically stock 5.3 to smoke them (on a track). And whenever people ride with me they comment on how nice it drives. Although lately everyone has been bugging me to get "pipes". Sheesh college kids.
Ill stay with the Corsa. Quiet until I want it loud
My Maggy is the same way, after 4k you don't hear it in the cab though, just engine and intake noise. I've been told you can really hear it behind the truck though. :lol:
All in all I'm very happy with my truck and there isn't much I want to change.
Edited by kstruckcountry
You want to change the engine
  • 6 months later...
Reviving this old thread because I want to and to say my gas cap cover is starting to rust from the inside out! Winters are harsh!
What's winter?
Other than a bit of rain havent seen much of winter
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
