Chit chat
SarahsGMC
Another car you don't see anymore. Looks pretty clean. And cheap.
http://tulsa.craigslist.org/cto/5744096509.html
That's true.. I came close picking up one of these a couple of years ago that was in absolute mint condition with low miles but someone else snatched it up first.
  • Replies 9.5k
I looked up the numbers and was a little disappointed. Not too quick, best test I found was 6.8 to 60, some as high as 7.8. Transmissions have come a long way in 10 years.
I've passed a white Sierra a few times outside of town. Done up really nice, lowered and all. As I was walking through town I saw it again. Turns out it's a Duramax!
At chic fil a and some insurance salesman is trying to convince a woman to buy whole life insurance for someone. Telling her the typical scam of the "investment" for her kids, if they don't die cash it in and all the BULLCRAP about it. With the internet, how do people fall for this crap. My wife's parents bought her some 20 years ago, it's worth like 7K now. $28 a month, yeah ,that's like a $300 return. A low yield savings account would have beat that. If only is worth it if they die, and even if they do, payout and cost is MUCH better with term like 5x the pay and 1/3 the cost
New neighbor with a super clean 2500, although I'm not sure if it's a duramax or not. I haven't paid enough attention or heard the engine.
Sent from my SM-G360V using Tapatalk
^^2001 or 2002 most likely with the 6.0 gasser unless they took the Duramax badge off. Looks good.
How do you know it's not an 8.1?
Good point. Still, odds are in favor of the 6.0 though.
Oh yeah, of course. I think the 6.0 accounted for like 75% of the HD trucks for the gmt800 platform (don't quote me on that)
Ugh, took my twins for their annual wellness exam. Told their doc to add my problems to their family history.....and she asked of I had any blood tests to verify. It's a seronegative disease(common for all blood tests to be clear, basically doesn't show on common tests).
I know not everyone doc can know everything, but dang, if I could find one primary care physician that looked it up BEFORE they talk about it(especially mine, who keeps ordering the same tests that won't show anything by the nature of it), it would be nice!
The Duramax/ Allison badge didn't come into play until the LBZ model trucks
What does lbz mean?
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
