Chit chat
SarahsGMC
  • Replies 9.5k
Sprained my ankle pretty bad yesterday. Pretty upset because my new Sig came in but I was in too much pain to leave the house once I got home. Here it is before it got even bigger
Managed to get to the size of a softball, then I got home propped it up and put some ice on it and it went back to that size lol
Sent from my SM-N920V using Tapatalk
The very back of my ankle where the tendon runs looked exactly like that when I crashed my motorcycle out in CA in '01. It never really went away, but shrunk considerably. I think I took the footpeg of the spinning bike there.
Thing hit the guardrail with it's rear tire, compressed the suspension, then shot the bike into my right shoulder. Talk about PAIN ... holy crapper. Bruised all my ribs.
All the damage to the tail of the bike was from hitting my body. That's my kneecap on the left. Bad day!
Second pic was taken long before anyone could ever dream of a "GoPro". One handed, 35mm film - not digital. :thumbs:
aaa%20CBR%20amp%20leg%20after%20wreck_zp
Ouch... hope it heals well and quickly..
Been walking on it all day, little sore but it feels good not setting on my ass
Keeping moving is good so long as you don't overdo it. Learned that the hard way once.
Yeah I'm not over exerting myself, just walking here and there, nothing crazy
Good move! Right about now you're probably starting to notice how many steps you actually take in a day...
Oh I can walk normally, it was sore at first and I could only stand on the balls of my feet but the more I progressed the less it hurt to put my full foot down. Still sore so I know to take it easy so it heals properly. Ain't my first rodeo, I've sprained my other ankle about 10 times lol
haha... An experienced veteran!
-24°C ( -11°F ) this morning, to my surprise hit the remote start on the truck and it started right up. Had to drive my daughter to the airport this morning 30 kms away and was monitoring instant fuel economy, not once through the whole 60 Kms trip did the truck go into V4, shows you how hard these role in the cold. Can you imagine what the grease looks like in all the bearings, CV joints, U-joints not to mention the consistency of differential and transmission lube. Truck thermometer read -25°C ( -13°F )
On cold mornings I usually let the truck go through at least one remote start cycle and then take it easy when I start driving it, let everything slosh around and get warm and coat everything
Wife's car won't start so have to drive her to work now, I'll check the AFM again. lol
So much for fuel economy today, Check engine light came on halfway with ''Engine power reduced'' made it home at 30 mph top speed. Checked code ''Gas pedal correlation error'' probably signs of things to come. Reset code all's good for now! May need a gas pedal sensor in the near future unless this -25°C has something to do with it somehow.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
