Chit chat
SarahsGMC
Cracked! WTF. :nonod: At least they made good on it.
Didn't that model just come out a few years ago?
The Cobalt ran from 2005 to 2010 I believe. Her Cobalt is a 2007 with 79k miles on it.
  • Replies 9.5k
Finally got around to changing the oil on the Versa, using my dad's driveway and ramps. I'm desperate for a garage!
Castrol 5W-30
Fram Tough Guard
New oil drain plug
Sent from my SM-G550T using Tapatalk
The Fast Lane truck or whatever the youtube channel is called put up their 2017 diesel comparison. Even though the Chevy is rated 7,000+lbs less than dodge and ford they still picked it as their winner.
GM has had the best diesel power train for ages. It's not all about numbers. So I'm not surprised.
Castrol 5W-30
Fram Tough Guard
New oil drain plug
Why aren't you using the XG6607 made for synthetic and synthetic blends? Synthetic oils tend to dissolve the glue holding the paper filter materials together used in conventional oil filters especially if you keep them in longer than 3000 miles. The XG has a hepa type filtration material and is made to last longer and filter better. I keep the oil for 12000Kms but change the filter every 6000Kms on my Cobalt.
Screenshot%202017-03-04%2013.19.22_zpsyl
Good question, I think I'll use that version next time. And I didn't know that the XG version was for blends and/or full synthetic.
How much oil do you use when you change the filter without draining?
I use the Wix 51522 XP, if you are set on Fram it would be the XG9837. These are for a trailblazer with the 4.2L. Same diameter and mounting thread, just a little longer. AC Delco is a PF61
Not a lot with the ecotec because it uses a cartridge that sits in a cup on top of the engine, maybe 50ml. Probably half a quart with the Versa
Wix is one of the better brands out there today. I use them, or Amsoil's filters.
That said, I used Fram filters for over 20 years without an issue, long before they came up with the different grade filters of today.
The better the filter the sooner it will go into bypass, so you really need to change the filter every 3000 miles ( 5000Kms ) like the manual says.
Going out in a little bit to check out the offerings for new toys aka a motorcycle [emoji16]
Sent from my SM-N920V using Tapatalk
Ok, I've been checking my Mazda dealer regularly, they are getting some interesting trades. They still have that 2015 Stingray with 7800 miles, they now also have a Elise, a 2013 Panamera, a 2015 Denali Sierra, a 2014 K2 crew cab LTZ with like 10K in off road stuff, and a one year old CX9 with 4800 miles.
Why the heck are all those people trading in for new Mazdas? They are all niche, under warranty, or vastly different(well, beisdes the Elise, you know what they traded in for).
But we all know the answer.
In my town one person owns a Ford,Toyota, Mazda dealer, with Ford being the biggest within two miles. That could explain the selection of use cars.
That hasn't been my experience. I do run the bigger filter, but I've run it for 8000 miles.
What vehicle are you talking about that requires a 3k oil change schedule?
What dealer is this?
Sent from my SM-G930V using Tapatalk
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
