  • Replies 65
  • 2 months later...
I just got done installing this thing tonight and it was a P.I.T.A!!! The instructions were not very clear at all, wound up having to find a youtube video of how to get the damn insert put in. Then it wouldn't tighten down because the insert kept spinning so i backed out the bolt and tried again and it stripped out! finally found a big ole screw in my toolbox and backed it up with a washer and got it to tighten up right. Great idea, just seems to be poorly engineered in places.
  • 1 year later...
Was down outside Orlando last week and swung by O'reilys and got one. Installed it this morning. Not sure I'm totally happy with how slow it opens. Totally not as slow as the video shows. The instructions say go to www.ezdown.com but it doesnt seem to work, just loads a blank page.
the old style the cylinder is a lot bigger than the new ones
Yeah, it seems they had a thin one, went to a fat one, and then back to the thin one. So I either have the really old one, or probably the new style. Either way, wishing it was a bit slower
I was perfectly fine with every frigging thing in my life as well as my truck until I seen this thread...... Now I have to have one of these damn things...... THANKS!
Yeah, I've felt the same way, somehow I've just never gone and done it yet....now the corvette servo...that'll be on order by the end of the week.
they work great is worth the money!!!! especially while carrying hockey equipment and dealing with a five year old!!
If you have a hosed shoulder and sometimes manage to drop the tailgate, these work wonders.
Life is even better after installing one because nobody can drop your tailgate anymore :)
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
