2011 Silverado LTZ, BL and Leveled, 305/55/20
Thanks everyone.
I was just looking at replacing the flat work truck grill with a 2011-13 HD grill colormatched.
Also removed the stock muffler and resonator last weekend, replaced with a spintech 9000 pro street dumped just before rear axle, and holy hell, the truck sounds like it should now!
Nice truck. Stop posting pictures or I'm holding you responsible when I'm single for buying that wheel and tire combo :lol:
Sent from my SGH-I927 using Tapatalk 2
Looks good lifted that way...Not a fan of the grille though. Why downgrade an LTZ front end with parts from a WT?
I did not like the chrome stock LTZ grill mine came with, it was not colormatched like you think. I have been looking at swapping over to a colormatched 2011-13 HD grill and possible hood.
Looks great. Grill...not so much. I would colormatch the factory LTZ grille. Those split grills look nice.
I did not think it was colormatched.....Just wondered why downgrade that's all.
no worries, just wanted to see how it would look with the tows and wt grill. It is good for now until I can get the parts together for a 2011+ HD hood and HD grill colormatched.
Nice truck, too much offset for me on the rims.
Nice rig man...looks killer! How do you like the TGC level kit?
I like it alot, would recommend it as a leveling option.
Thanks, offset looks like more than what it is....I would not want any less, otherwise just should have stayed with stock rims and tires.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
