Denali and 6.2L Revealed!
http://www.leftlanenews.com/gmc-sierra-denali-2014.html
Drew Johnson Wednesday, May 29th, 2013 @ 11:05 am
General Motors has unveiled the range-topping Denali version of its all-new 2014 GMC Sierra pickup truck.
Keeping true to the Denali formula, the 2014 version of GMC's most luxurious pickup truck comes fitted with a signature Denali chrome grille, body-colored bumpers, a polished stainless steel exhaust outlet and 20-inch chrome wheels. The new Sierra Denali also sports LED daytime running lights.
Inside the Sierra Denali pours on the luxury with heated and cooled leather front bucket seats, a heated steering wheel, a Bose audio system and bright door sills. In order to set the Denali apart from the standard Sierra, the truck comes equipped with an exclusive eight-inch Customizable Driver Display that can show things like audio or navigation information right in the instrument cluster.
The 2014 Sierra Denali comes standard with a 355 horsepower 5.3L V8, but those that live by GMC's 'Professional Grade' mantra will likely be more interested in the truck's all-new 6.2L EcoTec3 V8. Thanks to technologies like direct injection and variable valve timing, the 6.2L cranks out 420 horsepower and 450 lb-ft of torque – both tops in the light pickup truck segment. When properly equipped, the 6.2L Sierra Denali is capable of towing up to 12,000 pounds.
“The 2014 Sierra Denali has a combination of performance, capability and luxury that no other pickup can match,” said Tony DiSalle, vice president of GMC Marketing. “It leaves no boxes unchecked for those owners looking for the ultimate expression of ‘Professional Grade.’”
GMC will announce pricing for the 2014 Sierra Denali closer to the truck's market launch.
Read more at http://www.leftlanenews.com/gmc-sierra-denali-2014.html#q8GOQkrj27Ks2Jgp.99
  • Replies 59
So it looks like the 6.2 numbers have been released in a around of about way.
The drivetrain makes a good alternative for those who need to tow heavy but don't want the ride of 2500, only problem is that it will probably only be available in high end trim.
I'm liking that instrument cluster...and the fact that you can get this with a proper 4WD drivetrain!
But I still prefer the look of the All Terrain over this (all of the chrome is a real turn off).
The Denali was special. It only came with the big engine and was the only truck with AWD. They F'd it up
The AWD doesn't bother me since I prefer the proper 4WD transfer case, but for the GMT-900 and most of the GMT-800 life cycle, you could get the Denali engines in the other trucks (the 6.0L VortecMax's and the 6.2L's Sierra's and Silverado's).
Maybe iam old school but why does anybody need all that stuff on a pickup truck? The power then yes but everything else no. And those LED's around the head lights look like crap. Anybody knows that a truck like that is not used as a truck. If I had the money to spend on something like that it wouldn't be a truck like that.
Denali just said that you had the big engine and the AWD. All is now is decor on an SLT or SLT/NHT. I drove an 04 Denali AWD, 6.0, and 4WS. Loved it
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
No disrespect, but yes you're definitely just old school. Loaded/luxury trucks are for those that want a premium car/suv 90% of the time but also need the occasional utility a truck offers. When things do get dirty, it's nice to have a truck bed versus trashing the rear of an suv. My $0.02
I'm wondering if a dash cluster swap might be possible in the future... hope so. Sure would be sweet!
(I'm buying a SLT shortly... Denali is still a little out of my price range)
Definitely agree with this. My pickup has to be my daily driver 95% of the time simply because i NEED the crew cab, bed and 4wd. If I'm spending most of my time in a vehicle, I sure as hell want to enjoy it and be as comfortable as possible.
I like that they switched to a true 4wd transfer case, I feel like the high country is now more lux oriented than the denali though, the denali should at least get the black version of the high country leather. Also if those are the final number for the 6.2 the torque is good, but I am underwhelmed by the hp numbers, not that it will prevent me from getting the 6.2 in my next truck, but I was expecting more.
Nice job on the selectable transfer case in the Denali! (2WD / Auto / 4WD Hi / 4WD Lo)
Now we just need the 8-speed!
"Final SAE-rated power and torque numbers will be available later this year."
I must have missed it, where did it say there would be no AWD model?
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
