Most people will agree that a bilstein 5100 is the best all around shock for these trucks. The rcx nitro shocks that come with the kit aren't too terrible.
Well my RCX came in the mail today, such an exciting day haha. Going to I stall it and the 35s this Saturday oh so very excited!
I could only find the 5100s for 2014s with a 1-2" lift...??
Are the RCX 2.2s worth the extra money, and are either of the RCX shocks smoother than the stock shocks? I have to say that my stock truck rides like a damn stagecoach.
The rcx shocks are not as smooth as stock. I don't have experience with the 2.2s but they might just be worth it. One tip I can provide.... when installing the rear lift blocks and yiu have everything apart, grease in between the leaf springs. The design of the rcx fabricated blocks makes the leaf springs squeak if they're not greased. I just used a thick coat of white lithium
good to know i never would have thought of that and the constant squeaking would have driven me nuts!
yeah. with the u-bolts moved out it makes them rub each other more than normal. I learned the hard way and took it back apart. It's been good for months now though
My dealer had a sick looking ltz today... I don't think I could ever do it lol. I also couldn't justify laying 69k for a pickup
69k?!? I got my 5.3 sierra denali for 44k before my trade in. My 6" BDS lift was $1700, wheels and tires were $2200, lift install $1100. So idk where they're getting 69k from.
I am in the process of getting a 6" BDS coilover lift and 35" toyo mt's on 2015 silverado. I was wondering if anyone has had any issues with gearing or more specifically needing to re-gear after swapping up to a 35" tire? Anyone with this set, is the 5.3 beefy enough for that size. I am used to diesels and this is my first gas truck so I'm just not sure what expect.
I've got that exact setup and after the diablosport intune it runs a lot better. It's a little more sluggish from stock because the tires are so big and heavy but I doubt I'd ever regear. I'm putting a volant cai on this weekend too and lastly having diablew do a custom tune and then on to my headlights. Hope this helps.
+1, I got this with the stock block and it scared the hell out of me thinking it was drivetrain noise. Put the rcx in and greased it, no issues since!
I have a question i might be doing a 3.5 lift from rough country in the next few weeks... wondering if i can do 33x12.50r22 with some 22x12 wheels offset -44 ...is this possible with out rubbing or at least minor cutting...any pics of a set up like this
This is well documented if you'd search but I had 5"lift x12 wide wheels 33/12.50/22 and I rubbed pretty good, would have required metal trimming to get rid of. You probably won't be able to turn at 3.5"s of lift
Edited by baggedlvintegra
Wow what a job to put that RCX 7" in. Started at 7 am finished at 9 pm haha. I'll get pictures up as soon as I can. Rides pretty good. Little stiff out back but not bad at all. Good quality kit, terribly vague instructions. Overall very happy.
What tire/wheel setup went with that? And definitely show some pics
Rims are on back order so sadly it's sitting on the stock 17s and some 32s. I've got some 35s going on the 17s when I get my alignment done. Pics should be up tomorrow. Wheel tire combo is gonna be 20x12s with either 33s or 35s haven't decided yet.
Edited by matt_s
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
