What rear shocks did you go with on the zone lift? How do they ride?
I went with the Zone Nitro rear shocks and the Add-A-Leaf kit. The ride is excellent IMO.
Didn't see any but did you post fenderwell measurements? Im curious on my double cab if the aal will raise rear to high?
No, I did not post the fender-well measurements. I did not have the before the lift measurement. I will try and get the measurements some time this week.
So what would my off set being -12, with a 7" lift from this view. With a 35x12.50x20
Just curious
My Current Setup,2014 Silverado 2LT Z71,RCX 2.5 Level Kit,NittoTerra 33x12.50R20Lt's,Fuel - Octane D509 20x9 -12 Offset,All Chrome Plasti-Diped
My Up Coming Mod's,RCX 7" with 1.5 body Kit, Federal Couragia M/T's 35x12.50R20Lt's,OEM Tow Mirror's,Bushwaker OE Fender Flairs,Gtr Lighting Led Conversion Kit's 2,200 Lumen(High,Low,Fog),Black Spyder Venom Bull Bar,Iron Cross HD Step's.
Edited by 2014Sandylifted
Just curious
I would think that your tires would stick out further due to the negative offset. Mine are 0 (zero) offset on a 20x9. I wouldn't think that it would be significantly more (I could be wrong, and have been before, and will be again I'm sure. LOL), but it would be a little more.
Yea I have no clue lol
My Up Coming Mod's,McGhauphy's 7"-9" Economy Lift Kit,Federal Couragia M/T's 35x12.50R20Lt's,OEM Tow Mirror's,Bushwaker OE Fender Flairs,Gtr Lighting Led Conversion Kit's 2,200 Lumen(High,Low,Fog),Black Spyder Venom Bull Bar,Iron Cross HD Step's.
Oh ok sweet deal
So the OE bushwhacker flares I'm gonna put on will be perfect, thank you sscamaroburn02
No prob. Easy to figure out bs in future. Whatever your advertised wheel width says always add +1. Remember 1 inch converts to 25.4 mm
So yours would be -12/25.4=-.47. Now take your wheel 9+1=10/2=5. So 5-.47=4.53 bs. You can take off your wheels right now. Get straight edge and measure from that to mounting pad inside wheel. Easy to do and leaves no room for error. Your offset of -12 basically means your mounting pad sits inside .47 of centerline of the wheel
Edited by sscamaroburn02
Mind [emoji95]
anyone running the rough country 3.5" suspension lift? any issues with ride quality with the 3 inch block in the rear?
Edited by Bigmoore
Anyone with the 4" fabtech lift? What size of tire can I go without rubbing and don't want to trim. It's probably posted on here but couldn't find it
Sent from my iPhone
using Tapatalk
a3avegyz.jpg4y4yte8u.jpgty2umy8a.jpgymume9up.jpgmevytaze.jpghumyge6u.jpg rough country 4.75 lift, 20x10 Moto Metal 970's with - 24 offset, 305/55R20 Toyo Open Country AT II's Extreme. Minor rubbing in reverse at full lock on the plastic trim. Not bad at all.
Love your truck man. I love the look of my lifted double cab with the 6.5' bed. Nice!
