if you don't want something too crazy and different than all the other kits go for a 4" lift kit from bds or zone lift kit
The price is the same for the 4" and 6.5 zone kits.. so besides the height difference, why go with the 4"?
Is there a good reason to go with the 4" over the 6.5"
I ended up getting some method nv wheels on discount from 4 wheelparts Lol
i did the same :) see if coupon CC5OFF works for you.
Edited by arkenzo
I tried the code but it said expired but i can't complain about the price. Now i just have to wait for a good deal on tires. Btw do you have any new updated pics of your ride
Just preference i suppose. I was going to do the 6.5 lift at first but i didn't want to be like every single silverado out on the road. So i went with the 4.5" lift. Plus i wanted to run 35s on the smaller lift cause i like the look of more meatier tires and less gap around the fenders.
But to each their own right
Hahaha! Nice!!
personal preference. I used to have a lifted duramax which was pretty high as well as a bunch or other 6" or higher lifted trucks. I still want a lifted truck, but not as high anymore, so at least for me the 4.5" kit is perfect
Edited by wildchevys
No bro, honestly i haven't taken pics of my truck since the last ones i took, haven't had time to do much, taking care of my 2 month old is tough work!
yeah I'm in the same boat as you right now
I went with the 4 inch BDS for somewhat similar reasons. I wanted to add a little bit of off road capability, while at the same time, keeping the truck somewhat "professional" looking to the average person. I often meet clients at their homes, so I couldn't have a truck that was too neck - though I'll admit, if I wasn't using this truck as my daily driver, I would have gone with a bigger lift.
Good choice. Its lifted but not over done and you can still use it for normal work stuff.
Looking good man. Are those 33s?
thanks, and yes 33x12.5x22
prob should black out the headlight trim and grille sooner or later.
Edited by jerseytaylor
Any contraindications for towing a travel trailer and one of these 4-6" lifts? I was thinking 1100 lb tongue weight and 7500 lbs is a lot of strain and drop shank.
So let me get this straight. I have noticed that some of you have got the 4.5 zone lift and the fronts have raised more than 4.5 inches. Some almost as high as 6 to level out with the rears. This worries me as I only have 7 inches from the top of the onstar to the bottom of garage door. Once I do this lift and add 35s, I'm afraid it's not fitting in garage. Am I understanding this correctly?
I did the 6" BDS on 35s and I think my truck increased 8" overall when measured to the XM antenna. It measures 82" now and fits under 7ft garages with 2 inches to spare. As a word of caution, not all 7' garages are actually 7' tall in all places. Drive cautiously through parking structures.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
