Can someone clear something up for me.
I had a ReadyLift Leveling kit put on my '14 Sierra 1500 Both front and back.
I had asked what tires I could go with, currently I have 265/65/18
I saw an answer that said 33s
Unfortunately I have no idea what that means in tire size
Could someone give me an idea.
I am not looking for aggressive, just truck tires.(little bit aggressive maybe). I will eventually also be putting winter tires on different 18" rims as well.
any help would be good.
thank you in advance
33x11 is the max size. These will fit on a 2014+ on stock 18s:
275/65
285/65
275/70
295/65 <--- You're limited to the Goodyear Duratrac for this size.
305/65 <--- The only brand that I have seen posted that fits in this size is the Falken Wildpeak AT3W
If I was going to buy some replacement UCA so as not run the stamped steel, is there a Moog replacement that is cast?
Does anybody have pictures of a rough country 5" lift on stock wheels I am highly concidering this for my 14 silverado
Sent from my SM-G900V using Tapatalk
Here's my 14 with 5 inch rough country lift and stock rims 658a546fbef2702892e82150808a5610.jpg5f89a16c8b0cfa2035f7e2587f4919b7.jpg603986219b83be17a5fda0917f8d11ad.jpg
Sent from my XT1650 using Tapatalk
Nice!! Is that bracket or knuckle? Did you have to run spacers?
He's running :
2014 Silverado 1500 4x4 with rough country 5 inch knuckle lift and 295/60/20 nitro ridge grapplers.
.25" spacer in front and 2.5" spacer in rear.
6" bds with 20" cali offroad Americana and 35" nittos now i wish that never got installed... i now have the famous clunking noise its cool to drive but also very embarrassing to pull out of a parking lot without people wondering if my shit just broke lol
Edited by DIRTYDALE
Question to people out there with coilovers....How long has it generally taken you guys to install some front coilers.
Debating if I want to install mine myself or just pay some shop. I usually do all my work myself but have less time cause of work
An hour per side
Hmm, so I guess I'm not the only one with the clunking noise ? And I'm just on fox 2.5 coils and cognito UCA's
Is it your wheels hitting the front fender? If so check out the NorCal Mod. If you don't want to do the Mod just don't turn your wheels all the way. I have 2017 Silverado with a 6" Fabtech Lift, Fuel Assault 20x10 -18 offset, 35" Toyo Open Country R/T......minimal rubbing only when backing up and turning sharp.
Is the clunking occurring when you hit a bump or when you turn? Just curious.
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
