Thanks for the info. I'll have to check them out.
i think you'll be fine with 295/55, maybe slight rubbing. And Nitto and Toyo are the same company
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 AF Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
4.5" Zone
22x10 AF Grips
Thanks! Are you familiar with Rouch Country's 3.25" kit that combines the 2" level and 1.25" Body kit? I'm consider it as they claim you can run 33's on it... Might be an option. I know you said the 3.5" is junk and I'm not sure I want the 4.75" lift. Just consider options.
im not big on body lifts, but i DEFINITELY wouldn't run the 3.5"
4.5" Zone
22x10 AF Grips
Does anyone on here have any experience with the Rancho quicklift loaded struts?
I ran them for about 4,000 miles. They weren't bad but I couldn't figure out what number setting I liked the best. They did level the truck perfectly. If your in Southern California I'll give them to you.
Thanks, I am in Missouri right now. I cant decide if should do the Ranchos with 275/65/18 BFG's or bite the bullet and go with Fox. Any offroading I do is mild (hunting, fishing, etc.).
I would spend the extra $ and get the fox. Much better quality and ride.
I just had the Fox shocks put on with my Zone lift and my ride quality is just as good as it was when leveled. Never used any others, so can't comment on them.
I need some recommendations........ I purchased the CST 4.5" lift kit. I have cognito upper control arms, fox 2.5 coilovers and fox 2.0 rear shocks waiting to be put on. I am hesitant to do the install due to warranty problems. Guys with newer truck that are doing this, what is your opinion on moding the truck before warranty is up? Do I have anything to be worried about? If anyone has any input for me I would greatly appreciate it....!
2015 1500 LT Silverado Midnight Edition
Dealerships try to find something other than them to blame. That being said putting suspension components only void that part of the warranty. There was a case a while back that dealerships were blaming and denying the customer of warranty work by seeing items that had nothing to do with the items installed. The ruling was that if the dealership can prove your aftermarket equipment caused the failure they don't have to cover this up. Sometimes you have to remind the dealership this case happened and the ruling can have them sued real quick. Many stop trying to blame a component that doesn't have anything to do with your problem. Some are stubborn and you gotta go legal. Anyways. You shouldn't have to feel raped by trying to make your truck better and all those components other than cst as I really don't know what that is are way better than stock. Just a dealer being a dealer. Also many kits have factory warranty warranties such as bds, zone and pro Comp that if the dealership doesn't honor they will, and fix it. Just my own 2 cents
Edited by Csjumper2003
if you have a fair and legitimate dealer you should have nothing to worry about. I've had a lot of lifted trucks lifted within weeks of purchase that have gone back for service with no issues
4.5" Zone
22x10 AF Grips
4.5" Zone
22x10 AF Grips
I have too. But it's nieve to not recognize that can happen. And I've had people look at my truck and tell me a clunk in the rear of my truck could have something to do with the level kit I had put on. So then trying automatically charge me on that fact for diagnostic. I think it comes down to the dealership, and the service writer which works on commission.
I wouldn't sweet putting any of that on though.
4.5" Zone
22x10 AF Grips
i asked one of the service advisors today and they told me that would void all my warranties because it is not stock parts that came from factory
that blanket statement tells you right there that they suck
4.5" Zone
22x10 AF Grips
4.5" Zone
22x10 AF Grips
This. Also do some reading. Magnuson moss act. some of these dealerships need to get a life. They can't void your entire warranty due to some suspension components
i will definitely look that up and do some research!
4.5" Zone
22x10 AF Grips
i did forget to mention they said leveling kits were fine....
    DM22
    DM22
  • Who's Online   6 Members, 0 Anonymous, 1,148 Guests (See full list)
