10 hours ago, TXGREEK said:
If you do end up doing the CST lift, get the Stage 1, this way you can do whatever shocks and struts you want and when and if you want to add CST coilovers like me, you’ll have the CST upper coilover, strut and spacer assembly as backup or spares.
Thanks and Happy Thanksgiving, I've  had the Stage 1 kit sitting in my shop since July, week after I bought the truck. Had planned to install it this Winter when work slowed up. I'll be ordering those same coilovers when I'm ready to install it.
Happy Thanksgiving to you too. The best thing about this CST lift is once you add the these 4.5” specific coil overs, you can dial them up a bit too, (if desired) which will raise easily. Next week is the install, update afterwards. Be safe
What do I need to measure on my 2015 Silverado 1500 to see how much lift it has. I just bought the truck and not sure of the lift. It has RC parts on it. I measured the blocks in the rear and they measure 6” does that mean it’s a 6” lift.
Measure from the bottom bolt on the front cross member to the top bolt of the front cross member and that will give you the size of the kit.
Ended up going non resi foxes as the sac were ok deep backorder. Sucks but i can’t tell the difference.
Cognito uca with uniball
fox 2.5” coils - no adjustment out of the box. 2” lift
fox 2.0 rear shocks - no rear lift
Edited by Snicklephritz87
50k miles and I just installed new UCA's -- my ball joints were shot. I'm pretty certain it was the long miles with level kit and E-Rated tires that chewed them up.
which UCA's did you go with? how was the install?
I didn’t have a lot of choice or time—it was day before Christmas. I needed to take my truck on a long distance trip.
If I recall the UCA were made by Precision (OEM). I will consider aftermarket next time I need them. I was just surprised that they were already toast.
Truck hit 50k miles; lift has only about 8k miles on it. Before that it was level kit and E-rated 275’s.
Threw a 2” RC level on dads truck for Christmas. Still need to get another 1/2 inch inch on the front to get that true level, guess I know what I’ll get for his birthday [emoji2957]
Side by side with my 6” BDS. Love em both.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
