For Sale: 2000 Silverado 1500 4x4 Cracked Frame Rails
Post general questions to this thread. If you're interested in buying, then send me a private message. Vehicle is located in Novi, MI. Asking price: $1,750
Basic Info:
~185,000 miles
V6 4300 Vortec Engine
Regular Cab w/ Bench Seat
Lever activated 4WD
Cruise Control
Tow/Haul Mode
8‘ Bed Length
Full Size Spare
Air Conditioning
34gal Gas Tank
Additional Features:
Vinyl Tri-Fold Tonneau Cover (also can be sold separately)
Plastic Bed Liner
Kenwood MP3 Stereo Head Unit
Rubberized Floor Mat
Cargo Lamp
Two Front Bumper Tow Hooks
Nerf Bar Running Boards
Recently Replaced Items: Distributor Cap, Spark Plugs & Wires, Brake Pads & Rotors, Air Filter and Rear Leaf Spring Shackles
Spare Parts That Come With the Vehicle: Extra Rear Leaf Spring Shackle, Fuel Filter, & Tonneau Cover Cleaning Products
Good: 19mpg Summer HWY fuel economy, 8’ bed length useful for moving large items, AUX input on aftermarket stereo, & reliable 4WD engagement
Bad: Cracks on frame rails – buyer must repair (weld, brace, frame swap, etc.)! Must sign note acknowledging that you're aware of the frame's condition.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
