A/C compressor seems to turn off at idle
My 2001 Suburban is exhibiting some strange behavior recently.
The ABS light and brake light recently came on (getting some help on that on this thread: http://www.gm-trucks.com/forums/topic/152470-abs-light-and-brake-light-showing-up-at-once/?do=findComment&comment=1343182) and now my wife called me with the following news.
She was driving it this morning, and while she was driving, the a/c was blowing nice and cold. But when she stopped at the light, the fan continued to blow but no cold air was coming out. She also said that the idle seemed to drop just slightly, to around 500rpm (while she was in drive, with her foot on the brake). Once she started up again, the a/c resumed it's cold temp.
Some facts that might be relevant: It's a 1500 series with a 5.3 liter motor. The battery is 3 months old. I tested the alternator at the same time, and it tested out fine. The serpentine belt is under 3 years old, and appears to be in good shape. The vehicle has 187,000 miles on it, and has the original a/c compressor. Generally, all of the maintenance that needs to get done has gotten done over the last 9 years we've owned it, so it's been pretty well-maintained.
Any thoughts on this? Also, should the idle be that low in drive? With the a/c on, my wife said it felt like it was going to shut off.
Thanks in advance,
David
From your description, I'd check the fan clutch for proper operation for starters
Might want to clean the MAF and throttle body for the idle situation
txab,
Is there another way -- other than visually seeing whether it is working or not -- to check the fan clutch? Thanks for the tip on the MAF and TB -- I think I have the cleaners for those at home, so I'll give them a cleaning.
You can take some rolled up newspaper and slowly advance toward the fan blade, as you make contact if the blade stops or offers little resistance, it's toast. That's one way. Slow, no jabbing.
Fuel filter. Have you ever changed it?
Yes -- I forgot to mention that both the fuel pump and the fuel filter were replaced in April '12.
I'll try that trick with the newspaper. How does the engine fan impact the a/c system, though?
It pulls air across the condenser
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
its handy to have Tools to fix AC issues
  • UV leak set (black-light and special glasses) to check for leaking refrigerant
  • Multi-meter capable of testing Ohm resistance and Voltage in Direct Current to test electrical
  • Cans of RF134a to recharge the system
  • A/C Pressure Tester
Check that the pressure switch is activated
Locate the pressure switch.
The pressure switch is inline with the A/C coolant pipeline.
2
Remove the cap and connector from the pressure switch.
3
Test the resistance to the pressure switch.
4
An "Open" reading:
Indicates the pressure switch is not activated.
5
A "Closed" reading:
Indicates the pressure switch has enough pressure behind it to be activated.
6
If the pressure switch is activated, there is a problem with the electrical and the problem is more complicated.
7
If the pressure switch is not activated, check for pressure in the system
if loss of refrigerant due to a leak-- so you need to troubleshoot that
Just like your home AC unit uses a fan to pull air across it's condenser to remove heat, you truck's engine fan does the same job. At idle is where it can show that it is weak. You can have bad fan clutch without engine overheating. Lack of airflow across the condenser will cause an increase in vent temps because not enough heat is being removed from the refrigerant. Once the engine RPMs go up better cooling occurs again. Your fan clutch should be fully locked up (turning) when the engine is hot. When cold it should freewheel somewhat since not as much cooling is required
If you test the clutch, make sure the engine is at operating temps. Be very careful of course. If it's weak, it will stop or slow down without a lot of pressure against the fan blades
A couple of vids:
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
