The ones I got were something like these but a different brand. They were the black pods with the angle on them so when you mount them flush, they're aimed downward which I like.
https://www.amazon.com/Alpena-77003-UtilityLite-LED/dp/B00D1SWESY/ref=sr_1_83?ie=UTF8&qid=1483621621&sr=8-83&keywords=truck+bed+lighting
Thanks for the info. The lights look great. Need to do something to mine.
I am trying to figure out how to have a switch in the bed of the truck.
I do not want to have to go to the cab to turn them off and on.
Thanks again for the info.
Anyone have a spare plug from a second set they bought? I want to wire into the cargo switch with my aftermarket lights I already have but I don't have a dummy plug to modify...
I had one, but donated it to a local Austin area member...(I keep getting inquiries, hence the reason for the post). Thanks.
Cleaning out my garage after trading in my 2014 Silverado...found one of these plugs (no LEDs) from the GM Bed LED kit for a 2014 - 2015...if anyone interested PM me and we'll work something out to cover the cost of shipping...
I already found a local home for this plug.
Got my harness today, will be installing 12v light strips down the sides tomorrow. Great thread.
Hope you have better luck than I did. On my 13 I bought a kit from a guy on eBay, LED strips with adhesive on the back. Within a week in the heat they were falling off.
I've already bought the real 3M automotive strongest double side tape. I'll super Glue to the lights then use the good tape on the truck. Works a lot better than the crap the Chinese put on the lights.
Through some digging in found the harness part number for the 2016. It is 23327843. I just ordered mine from GM Wholesale Direct, they were the only ones with reasonable shipping.
http://www.gmwholesaledirect.com/oe-gm/23327843
Hope this helps!
I was about to order this until I realized the site was trying to charge me $32 for shipping. lol
Looks like I may go through the dealer.
I believe I've seen this asked before to no avail but has anyone figured out how to enable cargo lights while in gear? Or a workaround hack?
You'd need to setup a secondary hot with a 3 way switch. That way you can have normal operation, and an always on operation.
I think I figured out what the plug is on the factory wiring harness.
It's made by TE Connectivity:
Plug - 2109441
Contact - 968857
Wire Seal - 828905
Empty hole plug- 828922
http://www.te.com/commerce/DocumentDelivery/DDEController?Action=showdoc&DocId=Customer+Drawing%7F2109441%7FA2%7Fpdf%7FEnglish%7FENG_CD_2109441_A2.pdf%7F2-2109441-4
Edited by jimmyjames008
Plug - 2109441
Contact - 968857
Wire Seal - 828905
You didn't happen to find the light side of the plug did you? I've been putting off finishing mine because I don't really want to cut the ends off the main harness and go directly to the leds I have.
Here's more pics of my setup. Just need to install some better clips to hold the wires. b4aedaacb6f19180e0b4f71c535c3be1.jpg0dd601177bff4fa6ef0b9dd40f7db081.jpge27c58995cdb8c1162d5f7c716765f0a.jpgfbce0a468992b56e040b2c22699f9e23.jpg
Looks GREAT!!!!
My factory bed lights are nothing compared to these
Looks GREAT!!!!
Thanks man, for the price of these compared to what the dealer wanted for the factory option, I couldn't be more happier.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
