The ones I got were something like these but a different brand. They were the black pods with the angle on them so when you mount them flush, they're aimed downward which I like.
https://www.amazon.com/Alpena-77003-UtilityLite-LED/dp/B00D1SWESY/ref=sr_1_83?ie=UTF8&qid=1483621621&sr=8-83&keywords=truck+bed+lighting
Thanks for the info. The lights look great. Need to do something to mine.
I am trying to figure out how to have a switch in the bed of the truck.
I do not want to have to go to the cab to turn them off and on.
Thanks again for the info.
Anyone have a spare plug from a second set they bought? I want to wire into the cargo switch with my aftermarket lights I already have but I don't have a dummy plug to modify...
I had one, but donated it to a local Austin area member...(I keep getting inquiries, hence the reason for the post). Thanks.
Cleaning out my garage after trading in my 2014 Silverado...found one of these plugs (no LEDs) from the GM Bed LED kit for a 2014 - 2015...if anyone interested PM me and we'll work something out to cover the cost of shipping...
I already found a local home for this plug.
Got my harness today, will be installing 12v light strips down the sides tomorrow. Great thread.
Hope you have better luck than I did. On my 13 I bought a kit from a guy on eBay, LED strips with adhesive on the back. Within a week in the heat they were falling off.
I've already bought the real 3M automotive strongest double side tape. I'll super Glue to the lights then use the good tape on the truck. Works a lot better than the crap the Chinese put on the lights.
Through some digging in found the harness part number for the 2016. It is 23327843. I just ordered mine from GM Wholesale Direct, they were the only ones with reasonable shipping.
http://www.gmwholesaledirect.com/oe-gm/23327843
Hope this helps!
I was about to order this until I realized the site was trying to charge me $32 for shipping. lol
Looks like I may go through the dealer.
I believe I've seen this asked before to no avail but has anyone figured out how to enable cargo lights while in gear? Or a workaround hack?
You'd need to setup a secondary hot with a 3 way switch. That way you can have normal operation, and an always on operation.
I think I figured out what the plug is on the factory wiring harness.
It's made by TE Connectivity:
Plug - 2109441
Contact - 968857
Wire Seal - 828905
Empty hole plug- 828922
http://www.te.com/commerce/DocumentDelivery/DDEController?Action=showdoc&DocId=Customer+Drawing%7F2109441%7FA2%7Fpdf%7FEnglish%7FENG_CD_2109441_A2.pdf%7F2-2109441-4
Edited by jimmyjames008
Plug - 2109441
Contact - 968857
Wire Seal - 828905
You didn't happen to find the light side of the plug did you? I've been putting off finishing mine because I don't really want to cut the ends off the main harness and go directly to the leds I have.
Here's more pics of my setup. Just need to install some better clips to hold the wires. b4aedaacb6f19180e0b4f71c535c3be1.jpg0dd601177bff4fa6ef0b9dd40f7db081.jpge27c58995cdb8c1162d5f7c716765f0a.jpgfbce0a468992b56e040b2c22699f9e23.jpg
Looks GREAT!!!!
My factory bed lights are nothing compared to these
Looks GREAT!!!!
Thanks man, for the price of these compared to what the dealer wanted for the factory option, I couldn't be more happier.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
