I was excited about it because the reviews talk about how smooth of a ride they give compared to stock. I sometimes regret getting the Z71 over the standard 4x4 because of the stiff suspension in it. Potholes and speed bumps will jar your bones!
Oh, and do you have to get a new alignment with the quicklifts? I assume you would but not sure.
Yes you will need an alignment. They will lift the front end 2".
I had the Rancho Quick lift level kit on my Denali. The ride was better than stock but I took them off to put a 4" Fabtech lift instead. post-130662-0-77893300-1412736103_thumb.jpgpost-130662-0-27520500-1412736122_thumb.jpgpost-130662-0-56371100-1412736137_thumb.jpg
I had the Rancho Quick lift level kit on my Denali. The ride was better than stock but I took them off to put a 4" Fabtech lift instead. attachicon.gifIMG_20141007_214103.jpgattachicon.gifIMG_20141007_214034.jpgattachicon.gifIMG_20141006_120345.jpg
Did you add wheel spacers?
Yes 2" Spacers for a better look IMO.
Looks great! Do you have any pics looking straight at the front and/or the back? I have. 5" but thinking I want to do more. Lol.
Ok guys I have read the entire post haven't seen an answer to the set up I am getting ready to order. Wanted to get some input. Looking at a XD Misfit +0 offset. Will a 305/55/20 fit with no rubbing? Or do I need to go with a 295/55/20. Looking at putting fender flares on so wanted a tire that wasn't tucked underneath.
Truck Set Up
2014 GMC All Terrain (Z71)
2.5" Rough Country Lift
I think they pop out just enough.
Edited by 14GMC14
I installed the rancho quik lifts, so far I am very happy with them, the ride is better.
What setting did you keep them on when you had them? These look pretty cool!
Truck Set Up
Shouldn't rub with +0 Offset. My +20 offset rubs very slightly at full lock because they set in 3/4" and hit the sway bar.
What tire are you running? On your tag you show a 305/50/20. Im looking at a 305/55/20 which is a bit taller. May try a 295/55/20
Yes a 305/50/20 mine is a Toyo AT II 32" tall vs 305/55/20 is 33" tall I have plenty of room for a taller tire but the width on a +20 offset is the issue. a +1 would move the rim out 3/4" and I'd have no rubbing. There are other guys running 305/55R20 MT's on a 0 or +1 offset with 2" level and no rubbing on this forum.
The Rancho website says that these 2 inch QuickLifts are not compatible with the Z71 package. Does your Denali have the Z71 option? Any idea why? I do have the aluminum LCA's.
On the Rancho website it says they have 9 position adjustability. Is this for stiffness of ride or for lift height? (Or maybe for both if they are linked to each other).
I really want a 1.5" lift, but this does have appeal.
I wonder if they claim they are not Z71 compatible because it is not as stiff as the Z71 which is part of the point of the Z71.
    • You have to have the last word.
    • I am sure that was quite the pass experience and not a great place to experience during the winter when the conditions are not good. I've seen video of that pass and also more detailed information and pictures about the wrecks at that one hair pin turn where tractor trailers have flown right off the cliff and I am sure from all the warning signs that you know the exact curve that was !. After all there is a reason why a song was made about Wolf Creek Pass !. By the way and I didn't realize this either when I bought my truck as its nothing I even thought of that would be programmed into the cruise control and this occurs in either the basic or the more advanced cruise that controls your distance behind a vehicle and that is the brakes going down a hill are being applied as soon as the vehicle goes a certain speed over the set cruise speed. While it certainly does force downshifts in the transmission as you found out with cruise on while going down hill, its also dragging the brakes as needed to keep the speed controlled to what the cruise was set to. For me, I find that unsettling simply because I have no concept then as to how MUCH brake input is being used a and just how hot are those brakes getting and the wear factor as well. I can see that system getting a person into trouble on long mountain grades while pulling a trailer as it would not only be standing on the brakes of the pickup without any driver input, it would also be automatically applying the trailer brakes and it could cause a run away unit by overheating the brakes. Its one thing on a shorter hill and if the driver allows it to do its thing but on a long mountain grade is where things could get so out of hand. As someone a while back on this forum said, they had someone following them at night I believe on a down grade and had the cruise set and the person behind them could see the brake lights being energized all the way down the hill. I figured when I saw your comment that you didn't know and would have no way of knowing that your truck was applying the brakes and that you would and rightfully so assume you only used the brakes when you pressed on the pedal to slow down more than the cruise set speed for the slower sharp curves. So its good knowledge to know this about the newer GM trucks, certainly when doing any descending on long mountain grades. In the future try kicking off the cruise and use the the manual mode on a pass to see what that is like as I know myself when I first experienced it I thought no way can this engine be holding me back this well and tried the same hill in manual mode and sure enough the engine was revving way up and still could not hold the trucks speed down like it could in cruise mode.    Fuel mileage, that is where a really low sleek type of car can do better at higher speeds, certainly it starts sucking fuel too but a tall pickup is pushing massive amounts of air and also allowing a lot more air under it and the tow mirrors as in elephant ears pushing through the wind  as well. Driving like grandpa is about as good as one can do when driving one of these if trying to get the best fuel economy they can. I bet these trucks would get the best mileage they can if driven on a freeway in Florida if not busy traffic at a sedate speed and that sea level elevation without hills, vastly different then Colorado !.
    • It’s over for almost 24 hours. Are you playing Eddie Haskell?
