I just bought a 2014 1500 and am looking at putting the RC 2.5 leveling lift kit on it but they ask if the factory control arms are aluminum or steel. From the multiple dealerships I've called they have all said that they are cast iron. I know there are a ton of ppl on here with this kit installed so any help would be appreciated.
Black arms are steel
Sliver are aluminum
Would also be awesome if a company would make de-badged replicas of the new 17" Ram Rebel wheels. I like them.
Dodge-Ram_1500_Rebel_2015_1600x1200_wall
Similar characteristics of an all terrain wheel. Only ugly.
I didn't realize this was leveling kits, thought it was the tire wheels thread.
I love the all terrain rims. Just want smaller rims. 17" is perfect.
Not sure if it's been mentioned or not, but I went with the 2.5" motofab (eBay) upper strut spacer. Install was straight forward and everything fit well. With the 2.5" you don't have to cut the factory strut mounting bolts - so I can put it back stock later if I decide to.
Which kit do you have to cut bolts on??
I think I had read (maybe on here?) that the 2" upper strut spacers require you to trim down the factory mounting bolts. Heresay, obviously, but the 2.5" spacer installed without any trouble.
Before you speculate and cause confusion...with a 2" top spacer yes you have to trim the studs on the shock mount top hat. They aren't trimmed to the point you "can't go back to stock". There are plenty of threads left to properly secure the strut mount back after removing the spacer.
I have a 2015 Sierra Denali and I just put the 2.5" RC level kit on the front. I didn't add the rear block because it sits almost perfectly level now. The problem I have is that it rides like a dump truck now. The front is really tight and bouncy. It has been aligned professionally and everything but the ride is definitely worse than I had anticipated. Anyone else have this problem? The truck does have the factory 22" wheels and the side wall of the tire is pretty low profile but this has me thinking of taking it off completely. Any suggestions because Rough Country said they had never heard of this before?!
My 2014 LT Crew 4X4 has the RC 2 1/2" level/lift kit with complete install and I will agree that the front end seems stiffer and that the back seems mushy. I was thinking of trying the Rancho shocks on the rear of my LT to see if that would change (stiffen) things in the rear. I know it would effect the ride quality...
I have also given some thought to pulling out the upper spacer to reduce it to a 2" level kit since it's .5" and only gives you .5" of lift. Keep us informed.
I posted this in another thread regarding issues with the Denali and it's MagneRide and a levelling kit.
This is the thread:
http://www.gm-trucks.com/forums/topic/168618-leveling-kit-for-2015-sierra-denali-magnetic-ride/
Front sensors are not relocated, no. I drew these images up to hopefully explain it better.
Here's the stock setup, which remains the same with my lift. In both situations, the upper control arm does not have it's angle changed, as with a full lift the spindles are changed to longer ones and the shocks are extended down.
Now when you add a spacer above the coil, you cause it to reach lower, pushing the lower control arm down and bringing the front with it, as they're connecte with balljoints at the spindle. This lowering of the upper control arm negatively adjusts the magneride sensor.
Note the blue spacer added into the mix and the altered angles. Now the shocks are being energized, as the truck thinks its bottoming out, all the time.
A correct install would lower the sensor location or lengthen the linkage rod to compensate for the altered geometry.
My update: RC 2.5, Larger rear Block from RC and just had GY Durtrac 275/65R20's installed. Not rubs just had to up back inner liner with cable tie.
Beauty. That's exactly what I want to do with my crew cab standard box.
How do you like the setup after all this time.
I am surprised this hasn't been brought up to much yet but with the new bilstein adjustable and rancho loaded front shocks out, has anyone been using these at there stock height setting WITH a level of any size? Is there any limitations on doing this? I have a 2.5 rough country level with 285/60/20 LT duratracs and the ride isn't great after putting these on. Could be the 10 ply tires too. But adding these upgraded shocks should defiantly help me out, theoretically.. if it isn't going to damage the shock or anything else some how. I haven't heard of anyone doing this but it makes sense to me. Any insight on this would be great. I will also be keeping an eye open on other threads and let you guys know. Thanks!
    • You could try a used 1, they used that engine in the Astro vans, Plenty of them in the boneyard. Look for a wrecked or rotted 1 so the chance that it was scrapped for that reason and not a mechanical issue will be greater
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • That computer lies!
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
