2.5 rough country level w/ 285/75/18 toyo ats on stock Sierra wheels.
Any rubbing with that size tire? I'm looking at doing the 2.5 RC on my stock 18's as well. Was thinking of the 275/70 18s
In case anyone is looking for more data points on lifts, wheels and tires. I had a 2.5" Rough Country Level/Lift kit installed... and then installed 295/55R20 Toyo Open Country ATII Xtremes, with Fuel Maverick 20x9 Wheels in a +14. After having it done... I should have gone with the +1 offset... which would have stuck out an extra 13mm's, which is .5" inches. I would have loved to gone 305/55R20's... but I wanted to keep the Chevy mudflaps... and they would had to of come off. The 295/55R20's fit with an 1" to spare!
Let's see
At first glance that looks like a 2500. Looks good.
so to make a long story short..ive wore my eyes out reading the headlight threads already..now onto leveling it.
which kit is a front leveling only that isn't just reaming down the torsion bars or wont have the upper control arms hitting the frame at full extension. I have a 15 crew 2wd. sle. just like it to be level ..maybe even by removing a rear spacer?
thanks
Hey guys I am trying to go for this guys build (link below) although maybe a little less aggressive tires (ill take suggestions I want an off road look but don't want damper daily driving, because its really never gonna go off road just like the look). Also is there any difference between the 2014 1500 high country and the 2015 high country?
https://www.customwheeloffset.com/wheel-offset-gallery/8223/wheel-offset-2014-chevrolet-silverado-1500-aggressive-1-outside-fender-leveling-kit-custom-rims
thanks
No torsion bars on these trucks. Cheapest option and what your probably looking for any front spacer kit, try Motofab, Rough Country etc. They are all pretty similar. Either a top or bottom spacer, some are a combination of both once you go above 2.5ish inches.
Next option is Bilstein 5100 leveling shocks.
Most expensive is Fox, King coilovers etc.
No mechanical difference for leveling, wheels etc 14 to 15 that I know of. Id just copy what you see there. As for tires those are MT(Mud Terrains) if you want less aggressive go to an AT(All Terrain). Most popular are BFG KO2, Toyo Open Country AT2 , and Nitto Terra Grappler.
I have a 2.5" Rough Country Leveling kit... with 2.5" in the front and the 1" spacer in the back... and had no issue installing 295/55R20 Toyo Open Country AT2 Xtremes on Fuel Maverick 20/9 +14 offsets.
20160416 154121[1]
20160418 085331[1]
thanks..spacer kits are easy enough
Removing rear block is an option as well. Think I saw a 4wd guy do that somewhere on here.
So the suggestion (from the company) is to go with 305/55/20 BFgoodrich all terrains KOs on the 20x10 -24 fuel mavericks, everywhere I've read 305s aint gonna work with a 2.5 level?
what did ur wheels and tires cost you if you don't mind me asking
$2,900 out the door. Tire were like $350 ea.
Does Anyone know the fender height on a 3.5 level running 33's?(2014 Silverado LT)
Edited by Pigster
I'm looking to do this exact set up. Feel free to post more pics. Looks perfect
Not the best, but at least it's not in the driveway. I love the final product.
Sent from my Nexus 5 using Tapatalk
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,086 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
