Anyone with RC 2.5" kit getting a rattle or clunking? I've checked all bolts and everything is tight. This is in a 2016 Sierra
No one? How about this question - Does it ride like the spring are compressed? Lots of rebound over bumps?
No rattle or clunking here............just a rough ride therefore I'm going the Bilstein route. Rears today and fronts later.Good luck!!
What bilsteins are you going with?
I have been running 33x12.50s on mine for 50k mile now. put the 2" level and tires on when it had 900 miles. At full lock it will slightly rub the swaybar. I just ordered a set of 305/65r18 nitto G2s so we will see, but I anticipate the same results.
BTW... using the factory 18" wheels
You can't make this first post without pictures!! :nonod:33x12.50 on stocker 18s??!! Lots of us would like to see those pics. Post 'em up.
You can't make this first post without pictures!! :nonod: 33x12.50 on stocker 18s??!! Lots of us would like to see those pics. Post 'em up.
Edit: Nevermind
Just bought the front and rear 5100's. This RC kit sucks.
Edited by sensinitas
Still waiting! No pics.
I can't quite figure out how to post the pics. It says the file size is too large???
Nice. Thanks for pictures. What brand tires are they? What's your lock-to-lock rubbing when you hold it against the stop look like?
What do you think you gained by spending all that extra money on Bilsteins? Ride will be just as rough and the lift less. 2.5" max spacer Leveling kit (any brand will do) or 4+ quality knuckle lift. Anything else is throwing money away.
I haven't heard one complaint from anyone running the bilsteins. Also, seems everyone that upgraded from a leveling kit to the bilsteins are more than pleased with he decision
I always chuckle when I see those kind of posts. They act like a longer strut is better than a spacer giving you a longer strut.. Lol angles are the same, and nothing is really better feeling than the factory set up. You pay for a so so ride and less lift than a spacer kit lol just doesn't make sense. I'm gonna go with the RCX 2.5 then when the truck is out of warranty bds 4 inch
Sent from my treestand using Tapatalk
Me too. I hate to see the uninformed getting bad information from these forums and spending more money than is needed for a 2.5" level. Also silly is the debate about plastic versus aluminum spacers. I could almost agree about putting UCAs due to the extreme angles from a level, but I have yet to see anyone post that their stock ball joints are wearing out at 50K miles....and there are tons of leveled 2014s getting up there in mileage. And new UCAs are $800 plus install plus alignment....so you might as well let the stockers wear out first.
    TopBo
    TopBo
  • Who's Online   5 Members, 0 Anonymous, 1,696 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
